Geno 1,929 #1 Posted December 24, 2014 Need ID help with some stuff from the latest haul. I have a few things now and will have to take pics of a lot of other things over the next week or so as we get them out. This tractor has no model number - The grader is WH but has no number, the blade has 3 holes at the top like the blade can be flipped when worn - No idea what this is or who made it - This plow has no tag either - More to come later... Share this post Link to post Share on other sites
ericj 1,579 #2 Posted December 24, 2014 not sure what exactly the plow fits i believe it's for a vertical shaft tractor. i took one in trade several years ago in real nice shape and could not sell it so i cut it up and made a special project that i will reveal at the big show this year eric j 1 Share this post Link to post Share on other sites
Jake Kuhn 1,579 #3 Posted December 24, 2014 First tractor is a 1045....only 1100 or so made, was the transition tractor between round hood and square hood. The grader blade fits the 60's tractors, I believe the model number is mb405 but I'm probably wrong. Cultivator I don't know much about. And the snow blade would be for a vertical shaft but I"m not sure what model. I had one earlier this year and ended up just selling it so someone could use the front half for another blade as a lot of them didn't see much use. Jake 2 Share this post Link to post Share on other sites
WheelHorse79 271 #4 Posted December 25, 2014 Yes, that definitely looks like a 1045. It is missing the hood ornament and correct tires, but otherwise looks complete. There should be a little paper serial number tag on the left side of the tank stand just under the gas tank. Is it still there? If so, could you please provide the serial # in this thread? We are keeping an inventory of known 1045 serial numbers. Again, congratulations on such a nice haul! 1 Share this post Link to post Share on other sites
Geno 1,929 #5 Posted December 25, 2014 Thank you 79. The serial tag is still on it, I'll get it on here in the morning. I have the hood ornament for it and tires like I saw on yours on another tractor in the mix. Maybe it's all here somewhere... Share this post Link to post Share on other sites
squonk 43,770 #6 Posted December 25, 2014 That grader will fit just about anything I believe. I built a home made grader and I could put it on my 704, take it off and mount it on my 76 C-160 take it off and mount it on a C-145 I had without changing a thing. The mounting dimensions were all the same I think. 1 Share this post Link to post Share on other sites
wheelhorseman 3,236 #7 Posted December 25, 2014 Geno the grader blade will fit almost anything, yours looks the same as mine the tag is still on mine so here it is ---model 7 1112 6 and serial 793514 1 Share this post Link to post Share on other sites
Geno 1,929 #8 Posted December 25, 2014 So from what you guys say would the grader hook to the mid attach? Share this post Link to post Share on other sites
wheelhorseman 3,236 #9 Posted December 25, 2014 Yes, but your missing the lift linkage. Share this post Link to post Share on other sites
Geno 1,929 #10 Posted December 25, 2014 We can make that here. Share this post Link to post Share on other sites
wheelhorseman 3,236 #11 Posted December 25, 2014 Very good, if you need measurements let me know 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,471 #12 Posted December 25, 2014 The snow blade standing up should be one of these 6-7121 1970> 6-7122 6-7123 6-7124 66-42BA01 76-42BA01 86-42BA01 96-42BA01 06-42BA01 1980< Garry 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,471 #13 Posted December 25, 2014 10 different model numbers for the grader blade 1965-1982. Search the manuals using Blade grader pulled 40in Garry 1 Share this post Link to post Share on other sites
Geno 1,929 #14 Posted December 25, 2014 Thanks Garry. Got the serial on the 1045. Serial 21555. Share this post Link to post Share on other sites
Geno 1,929 #15 Posted December 26, 2014 Anybody got a good pic of the front tires that belong on the 1045? Share this post Link to post Share on other sites
rlrnot 39 #16 Posted December 26, 2014 the snow blade looks like the one I had no a charger 8 that I had. I modified it using angle iron to use on my 312-8. the model # is 6-7121. 1 Share this post Link to post Share on other sites
groundhog47 347 #17 Posted December 26, 2014 (edited) I concur with Wheelhorseman1000, and the 7-1114 (75) is about if not same and both are mid mount to attach-a-matic. Did you find lift link for it? Someone on here posted a drawing for fab up and someone sells ready made ones. or Very clean tractor pictured , would you when get a roundtuit measure grease cap id. Am lookin for what these fit, beside 8hp. Edited December 26, 2014 by groundhog47 1 Share this post Link to post Share on other sites
Geno 1,929 #18 Posted December 26, 2014 There may be one in these boxes full of parts still in the trucks. Share this post Link to post Share on other sites
sorekiwi 761 #19 Posted December 26, 2014 Agreed that the grader blade fits just about anything. I've had mine on everything from a 1067 to a 518. 1 Share this post Link to post Share on other sites
Callen 64 #20 Posted December 27, 2014 Geno, If you got any engines in the deal, look for a K241 AS as that would be the correct engine for that 1045 and a belt guard that may have remnants of 1045 in the off set. The belt guard is a bit different and only came on a 1045 and 1055. Should look like this one... 2 Share this post Link to post Share on other sites
Geno 1,929 #21 Posted January 3, 2015 Will do Callen and thanks. Got another mystery I dug out today... Share this post Link to post Share on other sites
Kelly 1,033 #22 Posted January 3, 2015 That blade looks a lot like a Simplicity off a walk behind 1 Share this post Link to post Share on other sites
Tristan Wilson 117 #23 Posted January 3, 2015 yes that's a walk behind blade geno whats the measurement of it 1 Share this post Link to post Share on other sites
Geno 1,929 #24 Posted January 3, 2015 It's 32" wide by 15" tall. Share this post Link to post Share on other sites
