lb7349 0 #1 Posted December 24, 2014 I have a wheelhorse c-161 and needed a new relay kit # 99-5365 but someone before me cut a lot of wires so do not know how to wire new relay Share this post Link to post Share on other sites
Molon_Labe 731 #2 Posted December 24, 2014 I assume that you have the B&S twin. Here is the link to the wiring manual And Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,989 #3 Posted December 24, 2014 The part number has changed but here is the service bulletin This is for a model using a B&S with magneto ignition. Make sure you do not allow any battery voltage into the magneto wire. That will burn up the coil. The relay simply grounds the magneto wire to stop the engine. The relay contacts when open allow the engine to run. Original wiring diagram If you are unsure about anything ask more questions. Garry Share this post Link to post Share on other sites
