jeremi3210 743 #1 Posted December 20, 2014 Anyone know if a old k241 from a 63 953 takes a different fuel pump from the newer engines? I am trying to get the original engine running but the fuel pump was missing, the one I got don't want to go in all the way and if you look thru the hole the cam looks different. Share this post Link to post Share on other sites
octfst 378 #2 Posted December 20, 2014 Not sure what fuel pump you have. But should fit if for a 10, 12, 14, & 16HP K-series or Magnum Kohler engine. Share this post Link to post Share on other sites
520HC 208 #3 Posted December 20, 2014 Your old 953 does take a different pump than newer engines. I would have to check part numbers to tell you what it takes. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,888 #4 Posted December 20, 2014 This parts list should be correct for the Kohler in the 953 Garry Share this post Link to post Share on other sites
jeremi3210 743 #5 Posted December 20, 2014 Thanks for all the replies. Good news I was digging thru my box of spare parts and found a fuel pump with a 90° bent lever put it in a it works. 1 Share this post Link to post Share on other sites
953 nut 63,394 #6 Posted December 21, 2014 You are lucky to find the original, The big plus is the primer lever on the pump. Unfortunately they stopped using that type in '66, I have changed my GT-14 and 312-8 over to the older (but better) pump so they start right up after sitting for a while. Please post a couple of photos when you get a chance. Share this post Link to post Share on other sites
