Gary520H 2 #1 Posted December 18, 2014 Hello all, I want to replace my current OEM tires with tri ribs. I cannot find tri ribs sized 16x7.50-8, only ones I have found are 16x6.50-8. Do they even make 7.50-8 tri rib? Miller tire only carries 6.50-8 tri rib. Any suggestions where to find these tires? Thanks Gary Share this post Link to post Share on other sites
shallowwatersailor 3,216 #2 Posted December 18, 2014 If you look at the tire specs on Miller's site, the 16x6.50-8 tri rib is only 0.1 inch smaller than the 16x7.50-8 Carlisle tires in that size. If you have Kenda 16x7.50-8 tires, they are about 1-1/2" taller. Share this post Link to post Share on other sites
Bert 760 #3 Posted December 18, 2014 The 6.5s from miller tire will fit fine. this is my 520 with a pair. 1 Share this post Link to post Share on other sites
Gary520H 2 #4 Posted December 18, 2014 Thanks to all that responded so quickly and picture. Looks like Miller tire is the one to use. Gary 1 Share this post Link to post Share on other sites
