zanepetty 117 #1 Posted December 14, 2014 (edited) How can I tell if a rod is .010 under or not? The seller doesn't know but he listed .010 in the title. The part number is b230039. It's a kohler rod. Thanks http://pages.ebay.com/link/?nav=item.view&alt=web&id=360493971019 Edited December 14, 2014 by zanepetty Share this post Link to post Share on other sites
rmaynard 16,837 #2 Posted December 14, 2014 (edited) Google Kohler B230039. Edit: Checking the eBay item you linked to, the number in the description is B230039-10, but the number on the box is B230039. Edited December 14, 2014 by rmaynard Share this post Link to post Share on other sites
oldredrider 2,553 #3 Posted December 14, 2014 Kohler rods .010 usually have a hole drilled in them near the crank end. 1 Share this post Link to post Share on other sites
wheel-mule 46 #4 Posted December 14, 2014 B230039 is a 7hp standard rod a .010 under would be B230039-10. Share this post Link to post Share on other sites
BradyS 6 #5 Posted December 16, 2014 Kohler rods .010 usually have a hole drilled in them near the crank end. If I'm not mistaken, shouldn't they all have a hole in the end? An oil hole is what it is called, I believe. Cub Cadet 1200 Cub Cadet 109 Cub Cadet 149 Cub Cadet "O" Cub Cadet SO76 Plenty of attatchments to put them to work. Currently looking for an RJ35, if you know where I can find one let me know. Share this post Link to post Share on other sites
rmaynard 16,837 #6 Posted December 16, 2014 That hole you are referring to is in the cap. Yes, they all have that. The hole mentioned earlier is in the rod. Share this post Link to post Share on other sites
BradyS 6 #7 Posted December 16, 2014 I see, thanks for clearing it up. Cub Cadet 1200 Cub Cadet 109 Cub Cadet 149 Cub Cadet "O" Cub Cadet SO76 Plenty of attatchments to put them to work. Currently looking for an RJ35, if you know where I can find one let me know. Share this post Link to post Share on other sites
kudzu3 323 #8 Posted December 16, 2014 I don't know Zane, but it is sure good to see you back here Share this post Link to post Share on other sites
