pfrederi 21,100 #26 Posted December 14, 2014 I assume your tractor has a coil and points. if it truly was converted to + ground then the wire from the ignition switch would be attached to the - neg terminal on the coil and the + terminal on the coil would go to the points. If it is wired teh other way the I would bet teh "conversion" was an accident not a planned thing. Share this post Link to post Share on other sites
Coley909 12 #27 Posted December 14, 2014 Coil is backwards That picture is the ground wire Share this post Link to post Share on other sites
Coley909 12 #28 Posted December 14, 2014 Does anyone know if the polarity is switched will the starter gen spin the other way? Share this post Link to post Share on other sites
Kegler 68 #29 Posted December 14, 2014 (edited) Not sure the reasoning behind it but I purchased a 417H set up on positive ground, Ran very rough but I rode it home. Havn't had time to get into it to see if it was intentional or just had the battery installed backwards. tractor is very rough with almost 2000 hr but for $200. I thought if nothing else I could get my money back in parts. But would rather get it straightened out. Edited December 14, 2014 by Kegler Share this post Link to post Share on other sites
Coley909 12 #30 Posted December 14, 2014 I'm switching it back as we speak. I found the starter gen spin the same way on either negative or positive ground. I thought maybe it was the wrong gen so that's why they switched it? Share this post Link to post Share on other sites
pfrederi 21,100 #31 Posted December 14, 2014 Not sure the reasoning behind it but I purchased a 417H set up on positive ground, Ran very rough but I rode it home. Havn't had time to get into it to see if it was intentional or just had the battery installed backwards. tractor is very rough with almost 2000 hr but for $200. I thought if nothing else I could get my money back in parts. But would rather get it straightened out. If I remember correctly the engine will run if the coil is wired incorrectly but it will burn the points rapidly and it won't run well. Share this post Link to post Share on other sites
Save Old Iron 1,573 #32 Posted December 14, 2014 Does anyone know if the polarity is switched will the starter gen spin the other way? The rotation will stay the same. The polarity of the armature IN RELATION TO THE POLARITY OF THE FIELD COILS remains the same. They are hard wired in that relationship inside the starter gen assy. ONLY BY REVERSING THE WIRING OF THE FIELD COILS can you change the rotation of the armature in relation to the housing. If I remember correctly the engine will run if the coil is wired incorrectly but it will burn the points rapidly and it won't run well. And the spark plug ground electrode will wear instead of the center electrode. 1 Share this post Link to post Share on other sites
Save Old Iron 1,573 #33 Posted December 14, 2014 (edited) armature rotation will change in a dc motor that has permanent magnets for the field (toy motors, etc.) starter gen's are shunt excited dc motors (the field coils are the "magnets") and the polarity of these field "magnets" are determined by their + and - hookups. Again, this hookup is hard wired inside the housing of the starter generator. Edited December 14, 2014 by Save Old Iron Share this post Link to post Share on other sites
Save Old Iron 1,573 #34 Posted December 14, 2014 (edited) Google is always your best friend. Computers, tablets and smartphone technology bring the entire realm of human knowledge and experience directly to your finger tips. I beg you all to not let your cloud curiosity begin and end with posting "selfies" and showing me what you ate for lunch on Facebook. http://www.homofaciens.de/technics-dc-electric-motor-wound-stator_en_navion.htm http://www.homofaciens.de/technics-dc-electric-motor_en_navion.htm Edited December 14, 2014 by Save Old Iron Share this post Link to post Share on other sites
Coley909 12 #35 Posted December 14, 2014 So I swapped everything and it runs beautiful I think my battery my be fried though and I'm only charging at 12.5 volts full throttle does that mean my regulator is shot as well? Share this post Link to post Share on other sites
Geno 1,931 #36 Posted December 14, 2014 (edited) I can't even find a 1075 manual in the manuals section here. Edited December 14, 2014 by Geno Share this post Link to post Share on other sites
Coley909 12 #37 Posted December 14, 2014 Haha it's a rare breed Share this post Link to post Share on other sites
Coley909 12 #38 Posted December 15, 2014 Does anyone know if the regulator is shot charging at 12.5 volts Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
ericj 1,580 #39 Posted December 16, 2014 to see if it is charging test the voltage of the battery with the tractor off then start the tractor and see what the voltage is, 12.5 volts does sound low for tractor running, should be over 13 volts eric j Share this post Link to post Share on other sites
Coley909 12 #40 Posted December 16, 2014 I'm going to assume it's shot because nothing was switched besides the battery being backwards Share this post Link to post Share on other sites
chip61 666 #41 Posted December 16, 2014 If there is a shop somewhere nearby that rebuilds starters and generators they can probably bench test the generator and regulator for you-regulator may just need adjustment which they should be able to do. Share this post Link to post Share on other sites
Coley909 12 #42 Posted December 16, 2014 Ah ok I'll see what I can find I was given the paper work for the shop the rebuilt the generator last year from the last owner Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,479 #43 Posted December 16, 2014 I can't even find a 1075 manual in the manuals section here. The 875 and 1075 share a manual Garry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,479 #44 Posted December 16, 2014 This old Kohler manual has a good section on the starter/generator Garry Share this post Link to post Share on other sites
