big mike 13 #1 Posted October 20, 2008 I picked up a C120 Auto with a broken rod....good thing I still have the fresh 10hp I can toss in it.One small thing is I cannot find where to release the hydro to push it.There is a decal pointing to 2 holes in the frame but there is nothing inside those holes....atleast as far back as a long screwdriver would reach.I'm not eaxctly sure what I am supposed to be seeing.Any help is much appreciated. Share this post Link to post Share on other sites
CasualObserver 3,414 #2 Posted October 20, 2008 I don't have any first hand experience, but here are the instructions from the manual. Hopefully someone can come up with a better picture... the scanned picture is pretty bad. Share this post Link to post Share on other sites
joebob 45 #3 Posted October 23, 2008 have you tried to lift just one side of the rear end off the ground I use a floor jack and have someone push and steer while you pull with the jack, the wheel that is off the ground will spin in reverse. this works for me and the valve release way is a pain in the @#* Share this post Link to post Share on other sites
BairleaFarm 344 #4 Posted October 23, 2008 Its not on the frame. The screw actully points towards the front of the tractor. It looks like a rod with a slot cut in it. Share this post Link to post Share on other sites
big mike 13 #5 Posted October 24, 2008 Was busy picking up leaves tonight so i'll have to look at it tomorrow night. Thanks guys. Now to figure out if I want to put a 10hp in it or let someone else fix the broken motor. Share this post Link to post Share on other sites
