whtractors24 3,335 #1 Posted December 9, 2014 I have a k181 c81 over charging the rectifier /regulator looks original all wiring is correct went through it on the wiring diagram.... I am getting mid 16s V to at the battery with a fluke amp meter.? Is it possible the rectifier regulator is bad and is not dropping the voltage enough ? Share this post Link to post Share on other sites
rmaynard 16,208 #2 Posted December 9, 2014 Make sure that the regulator/rectifier is securely grounded. Share this post Link to post Share on other sites
whtractors24 3,335 #3 Posted December 9, 2014 I'm pretty sure all terminals are clean bob... If it has a bad ground on the rectifier it will over charge. Or to bypass it I have leads can I ground the rectifier from its chassis to the battery ? Share this post Link to post Share on other sites
rmaynard 16,208 #4 Posted December 9, 2014 The body of the recitifer needs to be grounded. Try cleaning a fin on the rectifier, take a jumper wire with alligator clips, attach one end to that cleaned fin and the other to the (-) lug of the battery. A poor ground will cause the recifier to output a higher than normal voltage. Share this post Link to post Share on other sites
whtractors24 3,335 #5 Posted December 9, 2014 I'm going to try thay and also order one new from Stens at work for 35 bucks worth it to keep in stock. Share this post Link to post Share on other sites
whtractors24 3,335 #6 Posted December 10, 2014 thanks bob bad rectifier it was.. Share this post Link to post Share on other sites
