KC9KAS 4,744 #26 Posted December 4, 2014 (edited) Terminal Supply Company Part # 537A Here is the link for flashers for LED's http://terminalsupplyco.com/Store/Search.aspx?search=LED%20flasher&qs=true Everyone loves upgrading their trucks and trailers to long lasting LED lights, but you can run into problems if your turn signal flasher isn't built to operate with them. The problem is that a standard mechanical flasher operates based on the electrical current flowing through it, and one of the benefits of LED lights is the reduced current required by them. The result is that you have less current running through your flasher, and that current is outside the flasher's prescribed parameters. This can cause the flasher to operate erratically, flashing too fast or too slow. What you need is an electronic flasher meant for use with LED lights. All of the flashers shown below are up to the task. Edited December 4, 2014 by KC9KAS 1 Share this post Link to post Share on other sites
Lagersolut 746 #27 Posted December 5, 2014 (edited) Pete & Lager,,,ok,,got that part and thank you fellas,,,,,,,,BUT,,,,,,,just thought of this. Remember,,,,,every year we talk about FLASHERS. We have had many a talk on this.I allways wanted to do flashers to. The road I live on is high traveled going to the GS parkway. Thought flashers would give me a extra edge,,,,,so,,,,would we be able to hook up a flasher to these to? something like front and rear flash together,,,left side flash,,then,,right side flash,,left side flash,,right side flash. Front and rear at the same time. What kind of flasher to do this job? And would it work with the led lights. Judging by the amohnt of beer cans I pick up along the street on the front of my property,,,,everyone likes to finish thier brews before getting on the parkway and the state police gets them. Flashers might help the drunkies avoid me,,,,lol would love to put these on the 520 with the flasher set up. By the way,,,I found the ebay seller,,,got him on hold before I order. thanks guys,,,super good light / thread. Glenn See this link I had to do things different on my 310, has a 3 amp charging system with AC current coming right off the stator unlike the 15 amp systems that are coming off the battery , with the C-101 all that was needed was a splice on the output wire of the light switch, one switch runs both head and tail . The 310 was a little different, ( not chancing running the AC current to these low voltage lights ) found the hot wire on the ignition, installed a splice and I'm running through a second switch I fancied things up a little in the spirit of and installed a red LED toggle . I may order another for the restored C My tail lights will be in the mailbox tomorrow for this tractor Edited December 5, 2014 by Lagersolut 2 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,499 #28 Posted December 5, 2014 (edited) Ok, night reading / pondering. So if I get the led flasher unit that can also tie in to the regular bulbs in the front? I ordered a set of the rear bulls eye lights to. But, like you cant tell, I know absolutely zero on doing electric work. Also lager, that led light switch is the cats meow. Cool as can be and meets wheel horse fancy up standards. Imho Glenn before I forget, where did you get the "fancy" switch? Ty Edited December 5, 2014 by JERSEYHAWG / Glenn 1 Share this post Link to post Share on other sites
KC9KAS 4,744 #29 Posted December 5, 2014 Ok, night reading / pondering. So if I get the led flasher unit that can also tie in to the regular bulbs in the front? I ordered a set of the rear bulls eye lights to. But, like you cant tell, I know absolutely zero on doing electric work. Also lager, that led light switch is the cats meow. Cool as can be and meets wheel horse fancy up standards. Imho Glenn before I forget, where did you get the "fancy" switch? Ty You want to flash the headlights too? Yes, the flasher for LED's will also flash the incadescent bulbs. Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,499 #30 Posted December 5, 2014 You want to flash the headlights too? Yes, the flasher for LED's will also flash the incadescent bulbs. Yes sir, them to. Thanks for the reply. Glenn Share this post Link to post Share on other sites
Lagersolut 746 #31 Posted December 5, 2014 Ok, night reading / pondering. So if I get the led flasher unit that can also tie in to the regular bulbs in the front? I ordered a set of the rear bulls eye lights to. But, like you cant tell, I know absolutely zero on doing electric work. Also lager, that led light switch is the cats meow. Cool as can be and meets wheel horse fancy up standards. Imho Glenn before I forget, where did you get the "fancy" switch? Ty Jersey I sent you a PM . Share this post Link to post Share on other sites
Lagersolut 746 #32 Posted December 5, 2014 (edited) OK , got the lights in the mail today - took pictures through my install, hopefully it will make it easier - The lights - nice foam backing to pad the wires behind The connecters I'll use - butt splice - tap splice - Bullet connecter - 18 gauge wire ( not pictured spade connecter on switch and round eyelet connecters for the ground ) my Channel lock stripper and crimping tool does an excellent job on these For fastening I use # 10 x 24 1" machine screws with flat washers and double nut the ground wire on top of one the nuts - two small Philips head screws hold the lights/ circuit board to the housing I remove to get mounting screws into holes No drilling needed on this style fender pan - lights line right up Prop up the fender pan - the red wire is my lead All wired up, straight wire lead into either light , then bring the other lights wire over into a splice Here is the bullet connecter - this enables me to disconnect the harness/lights on the fender pan from the tractor in case it needs to be worked on tractor for whatever All lit up complete with new lighted volt meter wired into spade connecter on light switch ( volt meter from tractor supply ) Out the door Edited December 5, 2014 by Lagersolut 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,499 #33 Posted December 6, 2014 (edited) Great picture tutorial and man are those babies bright. I bet airliners overhead can spot you. thanks, Glenn eidt: I just spotted the brewskis by the tools, ah yes, there more important tools. Lol Edited December 6, 2014 by JERSEYHAWG / Glenn Share this post Link to post Share on other sites
