stormblue 0 #1 Posted November 27, 2014 270-h is it possible to convert the standard snowblower lift mechanism to hydroelectric set up.there is something wrong with my manual one .. it is very very hard and heavy to raise up .. I can almost guarantee you that 30% of your average men could not even do it .. it is that hard and heavy ...if I didn't know better I would say the lift assist Spring is hooked on backwards..I got a good deal on it used ...... so I thought maybe I would invest the money I saved into a hydraulic electric lift system does anyone know if this can be done ? it wouldn't be so bad if the spring lock for the up position worked .... but it does not .. the thumb button does not walk in anywhere as it should ... as heavy as it is ... I have to hold it up to move the tractor around Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #2 Posted November 27, 2014 Is this a 270-H tractor or do you want to add the 270-H hydro/electric lift to another model tractor? Garry Share this post Link to post Share on other sites
stormblue 0 #3 Posted November 27, 2014 (edited) it is a 270 H ... but doesn't have the hydroelectric option ...it has a long manually operated lift handle for the snowblower .. which requires extreme strength to lift and the lock button does not work bob Edited November 27, 2014 by stormblue Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #4 Posted November 27, 2014 Any chance you have the model numbers and serial numbers for the tractor and snowthower? Would like to look at the manuals and not familiar with this model. Garry Share this post Link to post Share on other sites
stormblue 0 #5 Posted November 27, 2014 the snow attachment is model number 79263 The ID tag that is supposed to be under the seat is gone ... so I have no idea what specific model or year of the 270 H is. The dedication tag is even gone from the Kohler engine ... The history of the tractor is unknown to the old lady I bought it from .. apparently her husband bought it used over a decade ago .. from the pictures it does look to be the K61A transaxle as opposed to the hydra-gear 3000 ... as those were the only two options for the 270-H series but from what I can tell the frame / chassis and all linkage parts look to be identical between all eight or nine models in the 270-h line ... and upon my limited knowledge of comparisons the only difference between it and the 270 HE is , in fact, the Hydro electric lift system as opposed to the manual one they all even have 20 horse Kohlers and all the models seem to offer the same part numbers or attachments I have surmised what little I do know from this web link you posted over on MyTractorForum. https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro Share this post Link to post Share on other sites
JustinW.73 224 #6 Posted February 4, 2015 Were you able to do this? I've been interested in doing this to my raider. Share this post Link to post Share on other sites
stormblue 0 #7 Posted February 4, 2015 (edited) no I was not.. but I finally tracked down the Hydro electric lift online .. but they cost is almost $1500 for just the motor/actuator throw in the different brackets and mounting accessories ... almost 2 grand for everything ... way beyond my price range see here: http://www.artslawnmowershop.com/OemParts?aribrand=TO#%2fToro_Consumer%2f72108%2c_270-H_Lawn_and_Garden_Tractor%2c_2002_(SN_220000001-220999999)%2fPOWER_LIFT_ASSEMBLY%2f72108-25804-2002%2f3324-691-%7c%7e6910022-00019 there are some complete garden tractors you can buy on craigslist for that much money that already have hydraulic lift mechanisms I did however realize that most of the lifting difficulty was due to a worn out front hitch mounting / swivel bracket ... replacing that has made the lift mechanism much easier to operate... Edited February 4, 2015 by stormblue Share this post Link to post Share on other sites
JustinW.73 224 #8 Posted February 4, 2015 HOOOOLLY CRAAAAAP! Guess I'll just try to fab my own setup. I got a guy that has an actuator that I'll be getting today. If I get mine working I let you know how it works if you want to. Share this post Link to post Share on other sites
stormblue 0 #9 Posted February 4, 2015 HOOOOLLY CRAAAAAP! Guess I'll just try to fab my own setup. I got a guy that has an actuator that I'll be getting today. If I get mine working I let you know how it works if you want to. by all means ..please let me know . I would not mind any of the rework or re-bracketing that would be necessary .. but there's no way I can afford that actuator .. I hope you're getting a good deal on it... and good luck cheers n beers Share this post Link to post Share on other sites
DennisThornton 4,773 #10 Posted September 12, 2016 On 2/3/2015 at 10:00 PM, stormblue said: no I was not.. but I finally tracked down the Hydro electric lift online .. but they cost is almost $1500 for just the motor/actuator throw in the different brackets and mounting accessories ... almost 2 grand for everything ... way beyond my price range see here: http://www.artslawnmowershop.com/OemParts?aribrand=TO#%2fToro_Consumer%2f72108%2c_270-H_Lawn_and_Garden_Tractor%2c_2002_(SN_220000001-220999999)%2fPOWER_LIFT_ASSEMBLY%2f72108-25804-2002%2f3324-691-%7c%7e6910022-00019 there are some complete garden tractors you can buy on craigslist for that much money that already have hydraulic lift mechanisms I did however realize that most of the lifting difficulty was due to a worn out front hitch mounting / swivel bracket ... replacing that has made the lift mechanism much easier to operate... There is a lift assist spring for them. I just bought a 264 with the spring. I must note that the owner said it didn't help much but he also said it fell off both times he tried it. Probably didn't have it on right either! Share this post Link to post Share on other sites
