Kpro 3 #1 Posted November 27, 2014 (edited) When my snow blade is lifted it is only about two inches off the ground, how can I adjust this? Thank you in advance, Kevin Edited November 27, 2014 by Kpro Share this post Link to post Share on other sites
slammer302 2,156 #2 Posted November 27, 2014 You would need to shorten the lift link or chain Share this post Link to post Share on other sites
bmsgaffer 2,065 #3 Posted November 27, 2014 You can also change the hole in which the lift arm attaches to the bell crank. the further from the shaft you clip the lift chain the higher it will lift (with a little more force needed if this is manual lift) Share this post Link to post Share on other sites
Kpro 3 #4 Posted November 27, 2014 I adjusted all three and now the blade lifts higher but will not lock in the up position. Share this post Link to post Share on other sites
shallowwatersailor 3,219 #5 Posted November 27, 2014 What model tractor? Do you have a Lift Control on it? Share this post Link to post Share on other sites
Kpro 3 #6 Posted November 27, 2014 it is a 310, just a lever. Share this post Link to post Share on other sites
Trouty56 567 #7 Posted November 28, 2014 might have went too far....maybe start with the lift handle locked in the up position....raise the blade and prop it with wood or something....then get the chain adjusted..... Share this post Link to post Share on other sites
bmsgaffer 2,065 #8 Posted November 28, 2014 (edited) Keep in mind too, that with manual lift, you will need to be able to lift the blade just slightly higher than the "locked up" position so that you can pull back a little to unlock it. So basically dont make it so high that its stuffed up in the chassis. I think mine only rides 2-3" from the ground when locked up... Edited November 28, 2014 by bmsgaffer Share this post Link to post Share on other sites
Kpro 3 #9 Posted November 28, 2014 Finally got it. I ended up removing the lift link and replacing it with a piece of chain. I went from 1 1/2" when lifted to 5". Thank you for all the help Share this post Link to post Share on other sites
