BDJudy 4 #1 Posted November 22, 2014 The carb appears to be a Tecumseh, it's on a HH-100 the numbers on it are 1203 F8P. There's also a 21B on the other side. Engine is on a 69 charger 10. It also has a fuel pump pushed into the fuel port, a model 3001 pulse. The fuel pump is leaking and the carb needs cleaned at best, thinking of getting a stens replacement carb and using a briggs plastic disposable pump. But can't figure out what stens or what rebuild kit to get Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
tbarnhart 240 #2 Posted November 22, 2014 Probably is a Tecumseh carb, but I can't tell without pictures. They can be hard to get right, but when they are, they run great and have a snappy throttle response. The fuel pump is a walbro. Kits to rebuild them are available on the bay. Search tecumseh fuel pump. The briggs pump would work as well, but I would spend the $10 on a walbro kit and keep it original. Share this post Link to post Share on other sites
BDJudy 4 #3 Posted November 22, 2014 Sent from my iPhone using Tapatalk Sent from my iPhone using Tapatalk Maybe a series 3 Tecumseh? Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
tbarnhart 240 #4 Posted November 22, 2014 Its definitely a Tecumseh carb. The kits to clean and repair it are easy to get and fit many of the tecumseh carbs. Just search for "hh100 carb kit". The fuel pump kit is a walbro "K1 pump". That pump is not pressed in but rather screwed into the carb. Its fairly easy to rebuild with the kit. As far as a replacement carb, I don't know. A lot of those carbs look similar but may have different venturi sizes for different HP engines. Tecumseh used that basic series of carb from about 5 HP to at least 12 HP. I'm not sure how to know which size you have and which size to get. Personally, I would rebuild the one I have unless the throttle shaft is worn too badly. Share this post Link to post Share on other sites
BDJudy 4 #5 Posted November 23, 2014 Thanks for the info, I'll check into the rebuild Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Kastlcj 5 #6 Posted December 3, 2014 Any knowledge on the make and model/number for a clinton 1200 carb? Share this post Link to post Share on other sites
BDJudy 4 #7 Posted December 3, 2014 Update, carb cleaned and running like a champ, pump rebuild kit on it's way. Plastic briggs pulse pump temporarily installed until kit arrives Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
tbarnhart 240 #8 Posted December 4, 2014 Good deal! Glad you got it working. Share this post Link to post Share on other sites
wheel-mule 46 #9 Posted December 7, 2014 I have a NOS carb rebuild kit $35 inculding shipping.I don't think that carb is available in after market. Share this post Link to post Share on other sites
