rollingflat 123 #1 Posted November 19, 2014 Here is my haul... I was just going to pic up two tractors an ORANGE one for my buddy and a RED one for me. Not sure what happend I think I blacked out for a few mins. or something.?! contents of truck and trailer are as follows: 74 c-120-8 speed 196?- 60? complete execpt hood w-10 horse tucm. motor po said he replaced the oem 8 horse tucm. 196?- 875 complete execpt motor 3 mower decks one for each tractor 2 snow plows ---one for the two older tractors very cool. set tire chains set wheel weights 16 hp kolher motor ...in the c-120 and one ac 717 for my buddy. 4 Share this post Link to post Share on other sites
KyBlue 655 #2 Posted November 19, 2014 Good Haul!!! Share this post Link to post Share on other sites
rollingflat 123 #3 Posted November 19, 2014 Dont know much about the older tractors so may need help to id them could not see any tags at first look. Also both older tractor also have slot hitches on them. Share this post Link to post Share on other sites
Molon_Labe 731 #4 Posted November 19, 2014 That is one sweet haul. Now for all the work that goes along with it! Ya done good!! Share this post Link to post Share on other sites
rollingflat 123 #5 Posted November 20, 2014 just more pics have not unloaded any thing yet. 1 Share this post Link to post Share on other sites
WheelHorse79 271 #6 Posted November 20, 2014 Looks like the 875 has the 1045 front tires. Can anyone confirm that? If those are 1045 front tires, then they are worth $80-$100 a piece. Share this post Link to post Share on other sites
Geno 1,930 #7 Posted November 20, 2014 You are Rollin now! Share this post Link to post Share on other sites
octfst 378 #8 Posted November 20, 2014 (edited) The one with out the hood looks like a 1964 704 it would have had a 7hp kohler. could be a 654 or 604 they had 6hp tecky. all would be 1964. Edited November 20, 2014 by octfst 1 Share this post Link to post Share on other sites
shallowwatersailor 3,216 #9 Posted November 20, 2014 Nice haul and a clean looking A-C 716 for your buddy. I miss seeing the moraine in Central Illinois traveling on 55. Share this post Link to post Share on other sites
rollingflat 123 #10 Posted November 20, 2014 Just back from weds. night church. Thanks for all the coments, question how can I definitavely ID the two older tractors? the one is a 875 but cant find tag to find out the year. the other one has no tag that I can find but it may be somewhere Im not looking. And PO thought it was a 60...something, thats all I have to go on right now. R there any special frame holes, bolts, or other oddites that Identify the round hoods? Share this post Link to post Share on other sites
rollingflat 123 #11 Posted November 20, 2014 Dont know if this helps but the 875 is an auto if that would lend it to a specific yr.? Share this post Link to post Share on other sites
octfst 378 #12 Posted November 20, 2014 875 is a 1965 & the other is a 1964 Share this post Link to post Share on other sites
rollingflat 123 #13 Posted November 20, 2014 More posible hints... looking at pics (because to dark and way to cold out) and saw round hood has a stright gear shift not bent up at end. has round gas tank with offset fill hole, and a rectangle stamped into the right side sheet metal below the tunel area. and has kind of a chrome plastic dash? Does this give any helps or hints? Im scouring every post and pic here trying to find the match! Share this post Link to post Share on other sites
rollingflat 123 #14 Posted November 20, 2014 octfst thanks for the help ,can you tell what model the 1964 is? Share this post Link to post Share on other sites
octfst 378 #15 Posted November 20, 2014 (edited) There is 3 models 604 654 & 704 The only difference is the motor. The 604 would be a 6hp pull start tecky, The 654 a 6hp electric start tecky, & 704 7hp Kohler Electric start. Since there's a battery box I don't think its a 604. Do you have the belt guard? that's where the number would be. Edited November 20, 2014 by octfst Share this post Link to post Share on other sites
octfst 378 #16 Posted November 20, 2014 I see the belt guard is cut off. there's a box stamped in the guard look and see if you can read the number. Share this post Link to post Share on other sites
rollingflat 123 #17 Posted November 20, 2014 ok ive been looking at the model yr. pics and came to the same conclution you have...654 or 704 will go look at guard. thanks 1 Share this post Link to post Share on other sites
rollingflat 123 #18 Posted November 20, 2014 tractor is at buddys house still loaded on trailer will have to wait till tomarrow. I think I know where your talking about the small pressed box on right side. its painted over but might show through w a little thinner.? thanks so much for all your help. will keep u posted on progress! Share this post Link to post Share on other sites
KC9KAS 4,745 #19 Posted November 20, 2014 Very nice haul! I have a 654 and a 875 (and 7 other WH GT's). I use the 875 to mow the yard with every week! Lately my wife has "adopted" the 875 as her tractor. 1 Share this post Link to post Share on other sites
rollingflat 123 #20 Posted November 21, 2014 Worked late and did not get chance to look at round hood to see if I could make out weather it is a 654 or 704. My gut tells me its a 654 because the PO thought it was a 6--something and that he said it had a tucm. motor that he replaced w a larger 10hp tucm. motor. he said the 10hp he put in it was new and run very little before he parked it in heated garage. which I believe because it has great compression. It has the right pulley for the mower deck which looks good so I think I'll try to find a round hood for it put deck on and correct seat and leave alone. As far as the c-120 after looking at it its a parts donor only. The good news is the motor in it is a very nice 16hp w good compression and the 875 is in great shape except its missing a motor i'm thinking good good canadate for an engine swap! what do you guys think can the 875 hood and frame handle the larger motor? its a WH I think it can ! But can I run the mower deck off the "newer" side pulley of the 16 or do I need to adapt the smaller pulley like what is on the round hood ? 1 Share this post Link to post Share on other sites
Hammerhead 817 #21 Posted November 22, 2014 Very nice haul! I agree with Wheelhorse79, those are the front tires from a 1045, yep they are rare and expensive! Somebody with a 1045 needs them. Share this post Link to post Share on other sites
rollingflat 123 #22 Posted November 23, 2014 Well, I was able to barely make out on the round hood belt guard that it is indeed a 654 thank you guys for all the help in id ing both the older horses. AS far as the front wheels on the 875 as talked about from some of the members I unloaded it today and gave it a once over the tires are in great shape and are 16x5.50x8 and say wheel horse made in USA. took one off and cleaned it up in the wifes kitchen sink you got to love em when they just walk by and say thier not surprised! Other than that I dont know any thing about them. pics to follow 2 Share this post Link to post Share on other sites
Geno 1,930 #23 Posted November 23, 2014 That's what sinks are for! Share this post Link to post Share on other sites
rollingflat 123 #24 Posted November 23, 2014 Here they r... 2 Share this post Link to post Share on other sites
953 nut 63,393 #25 Posted November 23, 2014 Rollingflat, you must have an understanding wife, or an old kitchen sink in your shop! Share this post Link to post Share on other sites
