psalms83:18 174 #51 Posted February 4, 2015 my snowblower chain is really loose but the tightening sproket is all the way out??? Should i remove a link?? or is there something else causing a problem?? Other than the chain loose nothing seems to be loose or worn to any degree of noticeability!? I do keep it well greased with some higher end sling resistant and water proof expensive grease. Share this post Link to post Share on other sites
psalms83:18 174 #52 Posted February 4, 2015 recently picked up a c-81 with mule drive and mow deck.... that should fit my c-175 right?? It did have a newer engine installed and is in good condition but i got it for cheap enough, was thinkin of snagging the mow deck off and sellin the c-81 and just break even!? Share this post Link to post Share on other sites
psalms83:18 174 #53 Posted February 4, 2015 i am lookin to build a couple improvised attachemnts for the c-175, disc harrow, york style rake, but im lookin to maybe buy a grader blade?? they make them for the c-175 right?? and i was thinkin a middle mount grader blade?? better than a rear mounted?? Share this post Link to post Share on other sites
bmsgaffer 2,071 #54 Posted February 4, 2015 (edited) Your chain is likely stretched and needs to be replaced. Can be had at your local farm store #40 roller chain (usually in a pack enough for 2) and get a set of master links too. the mower deck will work, yep you will want to look at getting a hitch designed for rear implements (slot hitch or clevis hitch, you can search for them) and a cable setup that runs from your lift arm back to the rockshaft in the back. Unless you use the midmount blade, then it just quick attaches... they are not real common, but you might be able to get a hold of one. Edited February 4, 2015 by bmsgaffer Share this post Link to post Share on other sites
psalms83:18 174 #55 Posted February 8, 2015 i got this awesome seat at my work (Bass Pro Shops) for like 15$!! Its great its waterproof leather(ish) and its RED Its called a "butt seat" used for fishin boats but i think its pretty comfortable, when i get it installed i"ll show a pic. Share this post Link to post Share on other sites
psalms83:18 174 #56 Posted February 9, 2015 the key circuitry keeps failing on me. I think there is to much rust inside of it. So i plan to make it a push button ignition, Any forseeable issues?? I like the push button ignition style. Also gonna install a horn so i dont have to get off it and call the wife or kid for somethin from the house-- lol --not lazy just more seat time!!! Share this post Link to post Share on other sites
psalms83:18 174 #57 Posted February 14, 2015 So I finally got the seat from bps installed. 15$ seat can't beat that!! I had to cut up one of my wife's brownie pans for a plate to line up all the bolts. But it's sturdy and is nice and low cut and comfortable!! Even better the seat fits right on the bracket nicely adjusts forward and back and there was holes in the bracket in just the right spot for a screwdriver to reach the bolts for the seat! As though it new this was the seat for it! Share this post Link to post Share on other sites
Spareparts 92 #58 Posted February 15, 2015 after reading through your post's I think you have a case of Wheel Horse Fever, bat part is their is no cure known to man, just keep feeding it. Watch out Geno you might have some competition soon. Share this post Link to post Share on other sites
psalms83:18 174 #59 Posted February 16, 2015 I can never reach geno.... But I do try to feed off the crumbs he drops !! Share this post Link to post Share on other sites
