motor12 367 #1 Posted November 13, 2014 After reading about the cracking problems on the frame where it connects to the trans I am having a 1/4 in. plate cut and fitted to this area. My question is, after bolting in place is welding also needed or is bolting enough, there is only one small crack on the lower left bolt hole about half an inch on each side of the hole. Thanks. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,888 #2 Posted November 13, 2014 Here is a service bulletin on it with poor pictures Garry 1 Share this post Link to post Share on other sites
PaulC 342 #3 Posted November 13, 2014 here is how I fixed mine...with slightly better photos 1 Share this post Link to post Share on other sites
rmaynard 16,761 #4 Posted November 13, 2014 My opinion is to weld it. 3 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,499 #5 Posted November 13, 2014 Like Bob says. Weld it. That's how mine was done. Glenn 1 Share this post Link to post Share on other sites
Geno 1,930 #6 Posted November 13, 2014 I would weld it as well. Share this post Link to post Share on other sites
ri702bill 10,824 #7 Posted November 13, 2014 (edited) I had to repair & straighten the trans mount on my 854. Lots of years of plowing took its toll - plowing puts a lot of vibration and torsional twisting force into that area. I made a 1/4" plate and added 4 1/8" gussets. I drilled thru the frame plate in 9 spots and plug welded the plate in place. Once the welds were ground flush, I gouged out the cracks down to the reinforcement plate & welded that up too. The gusset plates go into the area nead the bolts. Problem solved. Bill Edited November 13, 2014 by ri702bill 1 Share this post Link to post Share on other sites
Forest Road 595 #8 Posted November 13, 2014 If you have easy access to a welder. Then weld it. If not. I'd be comfortable without welding 1 Share this post Link to post Share on other sites
motor12 367 #9 Posted November 13, 2014 Thanks for the reply's. My 854 only pulls light duty, no plowing, mowing or heavy lifting. Her future is one of leisure. I figure after 50 years it's time for some R&R. Without access to a welder I plan on bolting in the plate and adding a support from the bottom of the tranny plate up to the frame like PaulC did with his. Thanks everyone. 3 Share this post Link to post Share on other sites
PaulC 342 #10 Posted November 13, 2014 Ya know that ole saying theres more then one way to skin a deer(most people say cat but I like cats to much ). Any way it gets fixed is a good fix and if your not doing any tough work with the tractor it probably doesn't even need to be fixed. I mowed and snowblowed a bunch before I realized mine was cracked. I realized when I made up a rear hitch for it and started to tow around my snowmobile trailer with sleds on it. Even then it just allowed the trans to twist enough to mess up the linkage. Since adding my bracket ive towed my 3 place sled trailer loaded so 2,000+lbs with 2-300lbs of tongue weight with no issues.....these tractors amaze me more and more everyday. 1 Share this post Link to post Share on other sites
