7316autohorse 4 #1 Posted November 11, 2014 I got a plow for my 73 wheel horse but it is missing the lever for adjusting the plow angle. The little triangle thing with a small rod going to the pivot locking pin is still there. I need pictures of the lever and whatever in connects to that actually moves the plow so I can build one or find one. One off the springs is also broken and half missing. Any idea where I can find one? I have been checking ebay but no luck so far. Any help would be appreciated!!! Share this post Link to post Share on other sites
Racinbob 12,800 #2 Posted November 11, 2014 I can't be of much help to you since it's been 15 years since I've had a snow blade but I do know that the triangular piece is a very easy part to make. You can find the parts diagram here but an actual picture with dimensions would help you out. I'm assuming you need one of the large springs on the blade itself. I'm sure help isn't far behind on both issues. Share this post Link to post Share on other sites
IndyFord2 51 #3 Posted November 29, 2014 Not a real good picture, but it may help Blade Dozer 42in 1974 6-2131 OM IPL.pdf Share this post Link to post Share on other sites
Tankman 3,528 #4 Posted November 30, 2014 (edited) Easy enough to make one using flat bar. Good luck with the broken spring. You might try eye-bolts and a couple of old auto hood springs. I've never done so but, I keep the idea in my noodle just in case. Take a peek-a-boo here: http://www.partstree.com/parts/?lc=toro_consumer&mn=06-48BC01%2C+48%22+Snow%2FDozer+Blade%2C+1984&dn=810224R3-24R30005-0003 Edited November 30, 2014 by Tankman Share this post Link to post Share on other sites
