vinnyfish1 9 #1 Posted November 8, 2014 So what are the thoughts on a Hydro tranny VS a HI/LO ..I have a 1984 C145 auto Share this post Link to post Share on other sites
slammer302 2,157 #2 Posted November 8, 2014 There lots of old threads on this subject if you do a search Share this post Link to post Share on other sites
Save Old Iron 1,573 #3 Posted November 8, 2014 It might be helpful if we knew specifically what you wanted to know. Your question is too open ended. 1 Share this post Link to post Share on other sites
RMCIII 839 #4 Posted November 8, 2014 Especially since the "xi" line has a "hi - lo" hydro! Rob Share this post Link to post Share on other sites
cleat 8,747 #5 Posted November 8, 2014 My Ford LGT165 has a hydro 2 speed rear end as well. I wish the 520's had that. Share this post Link to post Share on other sites
smoreau 658 #6 Posted November 8, 2014 It all depends on what you like. I grew up on a 875 and a hydro is the only way to go. But the 4 and 8 speeds have there advantages also. Some guys prefer them over the hydro. Hi lo is most likely in hi range 95% of the time, but is always nice to have that lo range when you need it. In all reality they are both great transmissions, you just need to find the one that fits you the best. Share this post Link to post Share on other sites
rick 270 #7 Posted November 8, 2014 For lawn mowing duties, I prefer the hydro since you can keep the engine RPMs up and control the ground speed closer to conditions, ie: rough ground, tall grass. For plowing and ploughing I prefer an 8 speed. Just my 2 cents! Share this post Link to post Share on other sites
vinnyfish1 9 #8 Posted November 8, 2014 Sorry about being so vague.. I think Rick answered my question Share this post Link to post Share on other sites
Tim 97 #9 Posted November 9, 2014 I prefer the hydro for everything except tilling Mowing, snow plowing, snow blowing is faster with a hydro. Changing direction is much faster. I find it hard to have ground speed control going real slow with the hydro. That is why tilling is better with the 8 speed. plus the hydro lift is awesome. When plowing and blowing. Share this post Link to post Share on other sites
MalMac 1,334 #10 Posted November 9, 2014 Most of us that have both will tell you that each has it's positives and negatives. I myself assign specific duties to each one. It's very much a choice of preference, but there are jobs that you will find out one works way better than the other. Share this post Link to post Share on other sites
RJR49 159 #11 Posted November 12, 2014 for mowing and blowing snow you need the hydro. Even with 6 forward speeds it's never the right gear for the amount of grass and snow facing you. For power it's the 8 speed. Pulling a load up a hill is a case in point. Tilling I suppose, maybe reliability /cost, but I can't think of any other reason to pick an 8 sp. Share this post Link to post Share on other sites
Road-Track 39 #12 Posted November 12, 2014 Don't forget the 8 speed is better hauling loads downhill . I use the 8speed for tilling and hauling and plowing mainly and the Hydro for mowing and snow blowing. All I need now is a tractor for each implement so I don't have to switch Share this post Link to post Share on other sites
RMCIII 839 #13 Posted November 12, 2014 RC - are you towing some 2,000lbs plus? Not sure about that. Yes, a geared tranny, does allow for a steady descent going down, but if the hydro is working properly, it will do nearly the same thing. Course this is my input about my knowledge from a "XI", not sure about the other models. I have heard up's and down's about them. Rob Share this post Link to post Share on other sites
Brrly1 1,146 #14 Posted November 12, 2014 Hydro!!! No matter what whether it be tilling, plowing or blowing snow. Loader is also on a hydro. Back blade on a C195. I have a couple as in two manual transmissions 701 and a C160 8 spd which I don't use. The 701 is just that I use it at the plow days but it's just for fun nothing I would use at home except maybe pull the aerator around the front yard. I have been more less spoiled by the hydro's but that's what I use 1 Share this post Link to post Share on other sites
