aaubrey96 0 #1 Posted November 5, 2014 I have finally figured out what to do with my free ex-pulling tractor, it's probably not what a lot of you guys would want to see but it's better than the scrap pile. Since none of the mechanical on it was good I've pulled most of it off and I'm going to restore the chassis and sheet metal to make and cool seat/shelve for the shop. But first thing I need to know is what is the best way to go about getting the steering wheel and column out of the dash to remove the dash? I would have to assume these use to be set screws of some sort. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
squonk 44,984 #2 Posted November 5, 2014 (edited) That's a roll pin in the steering wheel . Better start soaking the pin and shaft. Set screw on the lower collar Edited November 5, 2014 by squonk Share this post Link to post Share on other sites
aaubrey96 0 #3 Posted November 5, 2014 (edited) Ok. I should be able to drive out the roll pin and pull the dash piece up and off correct? Edited November 5, 2014 by aaubrey96 Share this post Link to post Share on other sites
CasualObserver 3,411 #4 Posted November 5, 2014 Yes. And from the sound of your project, you can just cut the shaft below the steering wheel. That's what I'd do. Share this post Link to post Share on other sites
aaubrey96 0 #5 Posted November 5, 2014 Ok. I want to put the steering wheel back in for the looks Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
JimD 3,347 #6 Posted November 5, 2014 (edited) Yes. If the steering wheel comes off easily then you can take the dash off to get the column out. Good luck, sometimes those roll pins are difficult. might be a good idea to soak it with a good penetrating solution for a few days before you try to drive it out. Oh I see Jason and I were answering at the same time. Edited November 5, 2014 by JimD Share this post Link to post Share on other sites
aaubrey96 0 #7 Posted November 5, 2014 I soaked it in oil last night and I'm going to let it sit for a while now Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
