Tankman
Work Horse Lighting
Tankman
Thinkin' 'bout changing the rear reflectors to LED tail lamps.
Trouble is my head lamps get dim or bright depending on RPM's. Power for lighting from the 16hp Briggs is in my mind, awful.
Is there another source of power for the lighting or can I just switch power to the battery?
Sorry, just a tin knocker, not too sparky.  :laughing-rofl:
oldredrider
As you said, the Briggs lighting circuit ain't that great. I had a GT-1142 with regular tail lights and it worked "OK". I'm guessing LED'S will work IF you don't need a minimum voltage to run them. Keep in mind the Briggs lighting circuit is AC voltage in your quest for LED's. You may have to run them off the battery for DC voltage.
There are lots of advantages to running Briggs engines wide open...bright lights is one of them!
