hckypck7 1 #1 Posted October 26, 2014 It starts and runs for 10 seconds then gas starts run out of carb and shuts off. Carb was taken off and soaked and cleaned, new fuel line, gas tank cleaned. I am going to change fuel filter. any other ideas . Share this post Link to post Share on other sites
Jparkes43 329 #2 Posted October 26, 2014 i'm thinking fuel pump if its not the filter. james Share this post Link to post Share on other sites
wallfish 19,037 #3 Posted October 26, 2014 If gas is running out of the carb, the float or the float's needle valve is not working correctly. Shake the float and listen for fuel shaking inside of it. Inspect the valve for damage. 3 Share this post Link to post Share on other sites
JustinW.73 224 #4 Posted October 26, 2014 Ya do exactly what wallfish said to do and go from there Share this post Link to post Share on other sites
hckypck7 1 #5 Posted October 27, 2014 Thanks for the responses. I will check float tomorrow. an replace filter. Share this post Link to post Share on other sites
boovuc 1,090 #6 Posted October 27, 2014 I don't know per your posts if you bought and installed a new Carb kit in the carburetor after cleaning. If your using the same components over, you need to install new. they are cheap. Definitely a float or float needle valve issue. My Magnum 10 was doing the old flammable liquid "waterfall" three years ago. A trip to my local NAPA and 15 minutes cured it. Share this post Link to post Share on other sites
Fordiesel69 271 #7 Posted October 28, 2014 Also after you have done everything mentioned above, if it still does it, you may have a leaky intake valve allowing blowback. Or a overly loose exhaust valve clearance. Share this post Link to post Share on other sites
hckypck7 1 #8 Posted October 28, 2014 The pin that the float pushes up to stop gas flow was missing. The pin the float pushes up to stop flow is missing....????? Share this post Link to post Share on other sites
Fordiesel69 271 #9 Posted October 28, 2014 Is this a question? If the needle valve is missing this would do exac tly as you describe Share this post Link to post Share on other sites
hckypck7 1 #10 Posted October 28, 2014 Not a question. I am trying to locate a kit for carb Share this post Link to post Share on other sites
Fordiesel69 271 #11 Posted October 28, 2014 So next you will need to determine if you have a carter carb or walbro carb. From there you will be able to get the correct kit. While rebuilding, check the upper part of the throttle shaft for looseness, and get a gallon bucket of berrymans chem dip to soak the carb in. It is not like the good old stuff but will work well. Share this post Link to post Share on other sites
hckypck7 1 #12 Posted October 28, 2014 Got it running. Runs like a top. Thanks everyone for your input. Share this post Link to post Share on other sites
oaktown1987 82 #13 Posted October 31, 2014 Does it spit or actually run out Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
WH nut 553 #14 Posted November 1, 2014 Got it running. Runs like a top. Thanks everyone for your input. So what did it take? Share this post Link to post Share on other sites
boovuc 1,090 #15 Posted November 1, 2014 His needle valve from the float was missing after cleaning the carb. He bought a carb kit and problem was fixed. Share this post Link to post Share on other sites
