B.Peters 1 #1 Posted October 25, 2014 I have a 1974 B-80 with a k-181. I'm having problems with it stalling out after it runs awhile like a 1/2 hour or so. It will just quit like the switch is turned off. But it will run crappy if I choke it then if I take the choke off it will quit. If I let it sit 15 mins or so it will run for a little bit and do the same thing again. Is my fuel pump getting weak or is it electrical. I took the line of the pump and it is pumping just don't know if its pumping enough. Could it be points? Any help would be appreciated. Share this post Link to post Share on other sites
rmaynard 16,700 #2 Posted October 25, 2014 Take the cap off of the gas tank and see if it keeps running. If it does, you may have a blocked vent in the cap. Share this post Link to post Share on other sites
B.Peters 1 #3 Posted October 25, 2014 I tried that already. Thank you anyway. I just don't know how a fuel pump acts before it goes completely out. Share this post Link to post Share on other sites
slammer302 2,156 #4 Posted October 25, 2014 I would check the float on the carb I've have the same problem every once in a while tap on the bottom of the carb with the plastic handle of a screwdriver and it will start running good again 1 Share this post Link to post Share on other sites
skrusins 128 #5 Posted October 26, 2014 I have a B80 with the same problem for a couple years. Finally I installed an electric fuel pump with a off and on switch. Have'nt had any problem all year. I talk to some guys at a rental store and said there installing them on all there equipment. Hope tis helps. 1 Share this post Link to post Share on other sites
B.Peters 1 #6 Posted October 26, 2014 I wonder if this new ethanol gas has anything to do with this. That new gas is junk in my opinion. 1 Share this post Link to post Share on other sites
JustinW.73 224 #7 Posted October 29, 2014 I wonder if this new ethanol gas has anything to do with this. That new gas is junk in my opinion. Thats a big fat yes. People have made tests on the new type of gas with ethanol and it is terrible for small engines. Especially the carb and gaskets. Share this post Link to post Share on other sites
WH nut 553 #8 Posted October 29, 2014 Replace the condensor Share this post Link to post Share on other sites
