Tim Bergfeld 55 #1 Posted October 21, 2014 So I am talking to a friend today about my 520 diesel project. He brought up a good point I am taking a great running rig and taking the motor off it to put it on the shelf. So what do you guys think buy a cheap 520 with a ragged out engine and use that. And if that is the case I need it to be tiller ready so I can use my tiller as well as the old snow blower to play with. Or should I just use my rig I wanted a diesel 520 for a while now and I have four small diesels to choose from out in the shop I think I am using the d722 turbo that's right the turbo diesel horsey Tim Share this post Link to post Share on other sites
bmsgaffer 2,069 #2 Posted October 21, 2014 Geno has a 520 with a shot engine but in otherwise great shape... You may want to talk with him. I think if you are going to throw a giant diesel in it, you should work up an 8 speed of some sort (not necessarily a 520). The hydro will probably be your weakest link (even though it is quite strong) but those 8 pinion 8 speeds are bullet proof. You can swap in the swept axle with a little work and the wider tires if that is important to you. At least that would open up the possibilities to many different models. Share this post Link to post Share on other sites
Tim Bergfeld 55 #3 Posted October 21, 2014 That's true I was just thinking thT model cause I had it Tim Share this post Link to post Share on other sites
km3h 543 #4 Posted October 21, 2014 A good running 510 is a nice thing to have in the stable. I have a motto. If it ain't broke, don't fix it. I would look for a 520 with a bad engine and go that rout. As for the transmission, I doubt it will make any difference, unless you ask it to do way more than the 210 HP Onan is capable of, which is a lot more than most folks ask it to do. In the end, it is your tractor and ultimately your decision. Good luck. Share this post Link to post Share on other sites
bmsgaffer 2,069 #5 Posted October 21, 2014 I did research and didnt realize that that engine was only 20hp. I was just assuming it was larger. In that case, the hydro should be just fine as long as its a relatively low hour unit. Though I still think the 8 speed will give you the best grunt. How do you interface anything to that flywheel plate? Ive never worked on the larger engines like that... Share this post Link to post Share on other sites
