Jerzguy2 23 #1 Posted October 19, 2014 1988 310-8 has Magnuum 10 and I cannot find a oil drain plug to change oil. Do you remove oil sensor to drain oil on this model? Thanks Share this post Link to post Share on other sites
Fordiesel69 271 #2 Posted October 20, 2014 Look at the deck tach a matic bracket of the right side of the tractor. Directly above it will be the plug. It will be kinda below the PTO on the base pan. Share this post Link to post Share on other sites
JustinW.73 224 #3 Posted October 24, 2014 yep. fordiesel69 is right but i think its the left side (driver view). It should come out the base of the block and come straight out if i remember. Its right above the mid tach a matic and on the back of the engine. hope this helps Share this post Link to post Share on other sites
Jerzguy2 23 #4 Posted October 25, 2014 Well, before anyone responded, I stopped to get a shifter boot at a Toro dealer, and they pulled up the motor on their screen. The plug was supposed to be under the carburetor. Finally stopped raining, so I cut some grass and went to change oil. I just had a birthday this week and I didn't think I was senile yet, but there is the drain plug on the right side under the pulley. Feel pretty stupid today, thanks to Forddiesel and JustinW for responding. Share this post Link to post Share on other sites
Kelsey 91 #5 Posted July 17, 2015 To everyone who helped in this thread a great big Thank You! Last night, my son dropped off his 310-8 that has a Magnum 10 for me to dosome preventative maintenance on. Without looking at the tractor, I looked this topic upand the drain plug was right where it was described. I'm thinking about putting in ashort nipple along with a 90' elbow and plug so that the oil will drain straight down. As usual, I'll charge him labor and the cost of materials in cold beer. 1 Share this post Link to post Share on other sites
WH3108CT 0 #6 Posted April 29, 2018 I found the drain plug from this thread, but where is the oil filter on the kohler magnum 10 1990? Share this post Link to post Share on other sites
pfrederi 19,785 #7 Posted April 29, 2018 (edited) There was none. splash Lube no oil pump Edited April 29, 2018 by pfrederi 1 Share this post Link to post Share on other sites
WH3108CT 0 #8 Posted April 29, 2018 Thanks pfrederi for the response. Share this post Link to post Share on other sites
