Ed Kennell 44,072 #1 Posted October 19, 2014 I have been searching the manuals trying to determine if a 36XR02 deck will fit on a '92 312-8 and if so what is the correct belt length ? I could not find anything in the tractor manual to confirm that this deck will fit. I have the deck, but don't have the tractor, or I would just install the deck and try some belts . I did locate the deck in the implement manuals section and it lists this deck as a 1984/84 but does not tell me what tractors it will fit. Will it fit any tractor with a mid and front Attach a Matic ? In the belt length manual it lists a no. 106433 HA/A 40.06" deck drive belt. The chart shows a HA/A as a 6 sided 1/2" wide belt. Will a regular 1/2" 4 sided belt also work? Some of the belt lengths are ~ 40" and some are ~80". Is the 40" just 1/2 the total length measured along the outside wide edge of the belt? Sorry for all the questions. Seems like I should be able to figure this out by now, but I NEED HELP. Share this post Link to post Share on other sites
ScottCT 15 #2 Posted October 19, 2014 I'm not sure about the belt but all the front and mid mount attach a matics are compatible.The only issues that I'm aware of are left hand tire clearances with some of the mower decks if you have one of the tractors with 8" wheels, particularly the 37". I swap attachments between my c121 and 312-8. Hope this helps you a little Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,917 #3 Posted October 19, 2014 The A5-36XR02 and 05-36XR02 fits the 1983-84 B-Series and LT-Series of tractors. HA/A (HA or A) is not the same as HAA which is 6-sided These decks do not use a six-sided belt. You should be able to use a search box in the top right of this file - enter just the 36XR02 Garry Share this post Link to post Share on other sites
Ed Kennell 44,072 #4 Posted October 20, 2014 Thanks for the link Garry. So I see the file only lists this deck as usable on the 1983/84 B and LT series tractors. I am curious as to the difference between these two tractors and the C and 300 series that prevents them from using this 36RX02 deck. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,917 #5 Posted October 20, 2014 This service bulletin may explain part of it Garry Share this post Link to post Share on other sites
