Rob R 977 #1 Posted October 16, 2014 Have K321 on a GT 14 with a small oil leak seemingly coming from the shaft (shroud side) of the engine, has anyone else experienced this and how difficult is this to repair..... assume that oil seal is bad, hoping I can accomplish replacement w/o removing the engine? Thanks Share this post Link to post Share on other sites
WH nut 553 #2 Posted October 16, 2014 Are you talking behind the flywheel? Share this post Link to post Share on other sites
Rob R 977 #3 Posted October 16, 2014 Yes sir appears to be coming from behind the flywheel........ Share this post Link to post Share on other sites
WH nut 553 #4 Posted October 16, 2014 On a GT I believe you will have to pull the motor, after that its pretty straight forward. Remove blower housing and flywheel and you are there Share this post Link to post Share on other sites
Rob R 977 #5 Posted October 16, 2014 Sooo you think you have to pull the motor to get the blower housing off? or is there some other reason .... I haven't had time to take a good look at this.... was hoping to know what I have to do from the get go. Txs. Share this post Link to post Share on other sites
WH nut 553 #6 Posted October 16, 2014 (edited) Its been a long time since I have seen a GT but clearance will be the problem. Never mind, just looked at a picture you should be ok. I was thinking of a D Edited October 16, 2014 by WH nut Share this post Link to post Share on other sites
Rob R 977 #7 Posted October 16, 2014 Okay thanks got it.... will get to it one of these days, maybe I can loosen the motor mounts and jack it up a bit, I am really hoping all I need is a new oil seal. Share this post Link to post Share on other sites
WH nut 553 #8 Posted October 16, 2014 Make sure the breather under the Carb is clean so it doesn't build crankcase pressure Share this post Link to post Share on other sites
Fordiesel69 271 #9 Posted October 16, 2014 Crank seal. Or the gasket between the bearing plate and block. You can leave the engine on. Share this post Link to post Share on other sites
Rob R 977 #10 Posted October 16, 2014 Okey dokey gentlemen will give this a try..... txs. Share this post Link to post Share on other sites
skrusins 128 #11 Posted October 16, 2014 I would clean everything really good first because the flywheel sucks and pushes oil from other areas like the valve cover, braether tube etc. Thats what I would do before tearing it all apart. Thats my opinion. Share this post Link to post Share on other sites
Rob R 977 #12 Posted October 17, 2014 Thanks for the suggestion can, will do. Share this post Link to post Share on other sites
Rob R 977 #13 Posted October 17, 2014 Going to get at the oil leak soon, I just picked-up this baby from NJ today..... many small things to fix besides the oil link .... typical due to lack of maintenance..... she doesn't shut off when key is turned-off assume this is the switch? Does this have a motor kill tab on the switch which goes to the coil? If yes will trace the circuit tomorrow or Sunday. Thanks P.s. it appears the coil or something related to the spark is attached to the shroud should I remove this first before taking the shroud off? Share this post Link to post Share on other sites
Rob R 977 #14 Posted October 17, 2014 Here's some pictures of the "beast" 1 Share this post Link to post Share on other sites
Rob R 977 #15 Posted October 24, 2014 Okay so today was the day..... Repaired the lights, electro magnet implement drive, refastened the solenoid, replace bad connectors and got the alternator charging. My good friend Ed Stoller came over and found where he thinks the oil leak is coming from.... in about ten seconds it appears to him that the oil is coming from the bottom of the fuel pump the more I look now the more I think he is correct..... question to my G14 experts...... is this an indication that the pump is N/G or does it just need a new gasket??? Thanks! p.s. I assume the best way to get at this puppy is to take the front end and gas tank off.... doesn't look like too much of a hassle? Share this post Link to post Share on other sites
oldredrider 2,553 #16 Posted October 24, 2014 An oil leak at the fuel pump indicates it needs a new mating gasket. Unless you are really small and nimble, removing the gas tank and heat shield is all you need to remove to gain access. Since you have had it running, your fuel pump is good and doesn't need replacing. 1 Share this post Link to post Share on other sites
Rob R 977 #17 Posted October 25, 2014 Progress Update: Removed all the Tin's today, seat and replaced the Hydraulic Lift pin with the correct pin last owner jammed a carriage bolt in the hole and bent it over.... had to cut it out with a cut-off tool.... Man this GT 14 is built like a tank ..... that done I proceeded to take off the front guard disconnected the lights and removed the nuts from the bottom and top of the front cast iron shroud but I could not get the shroud to come off took the spring holding device off the tank and the metal guard (heat shield) off but still cannot get the shroud off...... Question do you have to remove the tank frame bolts for the shroud to come Off.... Help.......! Share this post Link to post Share on other sites
Rob R 977 #18 Posted November 6, 2014 Update, the new Kohler OEM Fuel Pump gasket fixed the engine oil leak and I have gotten the GT 14 to a point where she is a going to stay until spring, running well and will be easy to get her ready for mowing next spring... pics attached. Thanks to all my fellow Wheelers for all the help provided! 3 Share this post Link to post Share on other sites
Aldon 4,828 #19 Posted November 6, 2014 I really like the pics! My efforts are on hold till spring but your update makes me want to start wrenching in my GT14's ASAP. 1 Share this post Link to post Share on other sites
oldredrider 2,553 #20 Posted November 6, 2014 rgrottk, Your GT-14 is looking good! If I might make a sugesstion, get a snow/dozer blade for it and have some fun this winter. You will be amazed at the pushing power of that beast. They're not just for summertime fun and if you miss this winter, you'll have to wait for a whole year! 1 Share this post Link to post Share on other sites
Rob R 977 #21 Posted November 6, 2014 If I could find a plow for a decent # I would consider it.... but then I would need chains etc. etc. My C-81 has both and that little puppy also pushes snow with a passion.... Share this post Link to post Share on other sites
KC9KAS 4,744 #22 Posted November 6, 2014 Nice looking GT-14. I used my 1969 GT-14 for plow duty last winter. I have rear indise weighte and 2-link chains. It worked very well! 1 Share this post Link to post Share on other sites
oldredrider 2,553 #23 Posted November 6, 2014 Since it has 15" wheels, common car chains will fit and are not expensive. Load the tires with winshield washer fliud or antifreeze and you have your weight. Easy-Peasy! 1 Share this post Link to post Share on other sites
Rob R 977 #24 Posted November 6, 2014 hmm the tires are 27" on mine I haven't measured the rims..... but it would seem to me that they are bigger than 15" ??? Share this post Link to post Share on other sites
Geno 1,930 #25 Posted November 6, 2014 They should be 15". Your tractor is looking really good! Share this post Link to post Share on other sites
