grinchsr
PARKING BRAKE KNOB REMOVAL 314H ????
grinchsr
I have a 314H model-73403 and need to know what the trick is to remove the plastic knob.  I see a pin sticking out the bottom of the knob but not enough to grab with a tool.  I started to drive a punch into the hole and only managed to bend the shaft the knob fits on.  Any ideas??????
gwest_ca
That is a 3/32" x 5/8" spiral pin.
You need to support the knob with a heavy object while you drive the pin out. A 2-person job.
Garry
cleat
And once the pin is out you can use a hairpin clip instead of the roll pin. That way you just pull the pin to remove the knob.
I did this on both of my 520's and it works great.
Cleat
daveoman1966
If you don't have a Roll Pin Punch Set.....  buy one. They have a special tip...not flat like a nail punch.  Craftsman has a $20 5-pc set and for $25 they have the same as a long-reach set.  I bought these a few years ago and they are indispensible.  You can, of course, spend a C note or more for a top-line set, but these haven't failed me yet.
Forest Road
Start with some penetrating oil. Then go for the Roll pin punch. I had one that had to be cut off. Good luck.
grinchsr
I was thinking about trying out my 10 lb wood maul..  LOL   THANKS for all the replies
Forest Road
It's a delicate operation. Better go with the 4lb mallet.
