grinchsr 654 #1 Posted October 14, 2014 I have a 314H model-73403 and need to know what the trick is to remove the plastic knob. I see a pin sticking out the bottom of the knob but not enough to grab with a tool. I started to drive a punch into the hole and only managed to bend the shaft the knob fits on. Any ideas?????? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,888 #2 Posted October 14, 2014 That is a 3/32" x 5/8" spiral pin. You need to support the knob with a heavy object while you drive the pin out. A 2-person job. Garry Share this post Link to post Share on other sites
cleat 8,230 #3 Posted October 14, 2014 And once the pin is out you can use a hairpin clip instead of the roll pin. That way you just pull the pin to remove the knob. I did this on both of my 520's and it works great. Cleat Share this post Link to post Share on other sites
daveoman1966 3,881 #4 Posted October 14, 2014 If you don't have a Roll Pin Punch Set..... buy one. They have a special tip...not flat like a nail punch. Craftsman has a $20 5-pc set and for $25 they have the same as a long-reach set. I bought these a few years ago and they are indispensible. You can, of course, spend a C note or more for a top-line set, but these haven't failed me yet. Share this post Link to post Share on other sites
Forest Road 595 #5 Posted October 14, 2014 Start with some penetrating oil. Then go for the Roll pin punch. I had one that had to be cut off. Good luck. Share this post Link to post Share on other sites
grinchsr 654 #6 Posted October 14, 2014 I was thinking about trying out my 10 lb wood maul.. LOL THANKS for all the replies Share this post Link to post Share on other sites
Forest Road 595 #7 Posted October 19, 2014 It's a delicate operation. Better go with the 4lb mallet. Share this post Link to post Share on other sites
