thehorse 221 #1 Posted October 14, 2014 Got stripped drain plug out tonight. I believe the transmission called for 5 qts of 10w30. I checked the fluid before draining and it read full. I'm betting only about 2 qs drained out. I'm sure there is some in the system but not that much. Filter is very loose and dipstick is out. Am I a dipstick and not realizing something? Share this post Link to post Share on other sites
Desko 636 #2 Posted October 14, 2014 It does take 5 quarts and a Napa 1410 hydraulic filter and maby the transmission was just low on fluid because they do get filled almost to the top. Share this post Link to post Share on other sites
thehorse 221 #3 Posted October 14, 2014 Got the Napa filter and installed it. Just not sure about what's up with the amount that drained. Dipstick read good. Thanks Len Share this post Link to post Share on other sites
grinchsr 651 #4 Posted October 14, 2014 HOW DID YOU GET THE PLUG OUT? Share this post Link to post Share on other sites
thehorse 221 #5 Posted October 14, 2014 I used the pipe nipple extractor.......Bought that set and a set of torx.....torx did not work......extractor.....LIKE A CHARM! thanks all Len Share this post Link to post Share on other sites
