scotty 252 #1 Posted October 12, 2014 my sickle mower is leaking oil how many seals are there and is there any napa cross numbers? Share this post Link to post Share on other sites
Trouty56 567 #2 Posted October 13, 2014 (edited) 2 seals....1 on the pulley shaft...1" shaft....and one on the wobble shaft....1 1/4" shaft..... Edited October 13, 2014 by Trouty56 2 Share this post Link to post Share on other sites
scotty 252 #3 Posted October 13, 2014 i cant get any of those seal number to cross Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,499 #4 Posted October 13, 2014 The 1232 seal is now 100863 at Toro and the CR replacement is #9815. The 1482 was replaced by 103118 and a CR replacement is CR12330. Has a 1.504" OD. SKF took over Chicago Rawhide (CR) and uses the same numbering system as does Napa. Garry Adding CR part numbers closely represent the shaft size - the bigger the shaft the higher the number. CR9815 for a 1" shaft - .9815" CR12330 for a 1-1/4" shaft - 1.2330" They can't be exact because there are too many variations/styles of the same size seal. 1 Share this post Link to post Share on other sites
scotty 252 #5 Posted October 13, 2014 ok that makes more sense thanks! Share this post Link to post Share on other sites
Trouty56 567 #6 Posted October 13, 2014 i cant get any of those seal number to cross sorry...the post I directed you to did not have the seal number for the 1" shaft....although the 9815 seal is on the cross reference chart....I should have followed through with that info for you..... Share this post Link to post Share on other sites
scotty 252 #7 Posted October 14, 2014 That's fine thanks for the help. Share this post Link to post Share on other sites
