motox25 36 #1 Posted October 11, 2014 Today I took the exhaust and intake manifold off my 520H to adjust the valves and noticed on the rear cylinder the exhaust mount doesn't seat completely on the block. It looks as if its bent or warped, the other side seats fine as does the front cylinder mount. If the muffler is only seating partially on the block on the rear cylinder could this cause damage to the engine? Is the only fix most likely a new muffler? Share this post Link to post Share on other sites
Desko 644 #2 Posted October 11, 2014 I'd try new exhaust gaskets and if you think its warped try a straight edge and see how much gap there is. Share this post Link to post Share on other sites
motox25 36 #3 Posted October 11, 2014 I put 2 new gaskets on today and tightened each bolt at a time and it is much more flush now, there may be a very small gap between the gasket and the block but it could also be the thick gasket. Share this post Link to post Share on other sites
HokieAg07 129 #4 Posted October 12, 2014 I had a hard time getting mine to seal with new gaskets. A little aerosol hi temp copper gasket maker did the trick! Share this post Link to post Share on other sites
Desko 644 #5 Posted October 12, 2014 Yea id go with the copper spray if it doesn't seal. Share this post Link to post Share on other sites
motox25 36 #6 Posted October 12, 2014 Aerosol gasket maker? Wow never even knew there was such a thing, how do you apply it? With the muffler installed? Share this post Link to post Share on other sites
HokieAg07 129 #7 Posted October 12, 2014 Yes, good stuff. Spray it on muffler flanges and both sides of exhaust gaskets. Share this post Link to post Share on other sites
