Kpro 3 #1 Posted October 6, 2014 Is here a way to adjust the brake pedal? I am 6' tall and it is all I can do to fully engage the brakes just to set the parking brake. Also when the brake is released the pedal folds backwards. Is that supposed to happen? Thank you, Kevin Share this post Link to post Share on other sites
rmaynard 16,609 #2 Posted October 6, 2014 How's the brake lining? Original lining was about 3/16" thick. If it's worn too much, you will have to push the pedal farther. As far as the pedal coming back too far, check the foot rest to see if it's not bent down where the brake pedal rests when it returns. The brake is adjustable. I will try to find the proper adjustment procedure for you if you give me your 310-8's ID number. Share this post Link to post Share on other sites
Kpro 3 #3 Posted October 6, 2014 (edited) As far as the pedal, duh, it should have been obvious, the footrest was bent. The lining on the band does not look bad at all. My ID number is 21-10K805. Edited October 7, 2014 by Kpro Share this post Link to post Share on other sites
