waltsuz 12 #1 Posted October 5, 2014 Does the front engine mount on a D250 bolt to the engine/frame cross support or just set on it. Mine appears to just set on it as I can actually lift the engine off the support by hand..thanks in advance,, walt Share this post Link to post Share on other sites
stevebo-(Moderator) 8,742 #2 Posted April 7, 2015 Did you ever figure this out? I used my D250 today and heard a noise. When I moved the engine found it was coming from the front engine mount. I would like to know how it is attached too. Hope it is not broken rather just a loose nut perhaps? Share this post Link to post Share on other sites
stratostar250 934 #3 Posted April 7, 2015 I can try and check mine out if you need, guys. But I have no guarantee mine will be correct either Share this post Link to post Share on other sites
