jeremi3210 752 #1 Posted October 5, 2014 Fun plowing with my 702. Pulls the 8 inch plow great. 6 Share this post Link to post Share on other sites
KC9KAS 4,746 #2 Posted October 5, 2014 Looks good. Have any problem with the ags spinning? Do you have additional weight on the rear? Share this post Link to post Share on other sites
jeremi3210 752 #3 Posted October 5, 2014 No weight. It could use some, it did lose traction some but if I leaned back it would grip. Share this post Link to post Share on other sites
squonk 48,036 #4 Posted October 5, 2014 Awesome! I plowed last Sunday with a 8 and 10" behind my 73 no -name 12. Weights and filled tires never spun at all. Messed up my back some with the bigger plow though. It's a handful to get out of the ground! Share this post Link to post Share on other sites
jeremi3210 752 #5 Posted October 5, 2014 I usually use my 953 with my 10 inch plow but I just picked up this 8 and wanted to give it a try. Share this post Link to post Share on other sites
Firpo701 408 #6 Posted October 5, 2014 Awesome! I did all of my plowing last spring with the 701. I believe us guys have entirely too much fun!!! Lol! :-P Share this post Link to post Share on other sites
jeremi3210 752 #7 Posted October 5, 2014 It is a blast!! Only problem is the garden is to small I could do this all day. 1 Share this post Link to post Share on other sites
Geno 1,931 #8 Posted October 5, 2014 Nothing like riding the 1 Share this post Link to post Share on other sites
Firpo701 408 #9 Posted October 5, 2014 Awesome! I plowed last Sunday with a 8 and 10" behind my 73 no -name 12. Weights and filled tires never spun at all. Messed up my back some with the bigger plow though. It's a handful to get out of the ground! Know what you mean. I broke my lift cable getting mine out of the ground. I replaced it, and then started backing up a little bit at the end of the rows...made it a heckuva lot easier lifting it out of the ground. :-) 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #10 Posted October 5, 2014 Looks like fun. Share this post Link to post Share on other sites
ericj 1,580 #11 Posted October 5, 2014 (edited) i have no problems lifting my 12" plow out of the ground. my, 520-H lifts it real easy eric j Edited October 5, 2014 by ericj Share this post Link to post Share on other sites
groundhog47 448 #12 Posted October 7, 2014 (edited) Fun plowing with my 702. Pulls the 8 inch plow great. Notice pitch of plow raised is almost level in relation to ground. I've been trying for two days to set my plow believe 12" same frame as yours. I've changed to almost pointing 45 deg @ full lift and all in between with coulter wheel from low to high and all in between also. Plow just rides on ground with slack on lift chain and using hole on clevis 3/4' from top and 3r position on plow draw hitch. Is it thick sod can't be plowed or is adjustment is just incorrect. (C-120 low, double low, and low 2nd pulling speeds, ag tires, no spinning). Any help appreciated Edited October 7, 2014 by groundhog47 Share this post Link to post Share on other sites
squonk 48,036 #13 Posted October 7, 2014 How about a pic of the plow resting on the ground. Here is the pdf from Brinly. It tells you how to adjust the plow depth http://brinly.com/graphics/manuals/PP_51BH.pdf Share this post Link to post Share on other sites
groundhog47 448 #14 Posted October 7, 2014 Mike, thanks, will try for pic tomorrow. Got up a little better with coulter wheel raised clear like you said and got a fair start till ran into roots an spun. Will need to add wheel weights for sure. jeremi3210 din't mean to high jack your post, but you got a job done I was having a big prob with, thanks for your post Share this post Link to post Share on other sites
jeremi3210 752 #15 Posted October 8, 2014 I don't mind groundhog47, that what this site is for helping each other out. I set mine up so the back is about a inch up when resting on the ground. Share this post Link to post Share on other sites
Pullstart 71,191 #16 Posted October 8, 2014 How about a pic of the plow resting on the ground. Here is the pdf from Brinly. It tells you how to adjust the plow depth http://brinly.com/graphics/manuals/PP_51BH.pdf I never noticed the little farmer and his hat. tell you what, that's a killer hat! Share this post Link to post Share on other sites
groundhog47 448 #17 Posted October 8, 2014 (edited) I don't mind groundhog47, that what this site is for helping each other out. I set mine up so the back is about a inch up when resting on the ground. Thanks getting ready for pics when camera charged! It's great when a bunch helps each other and easier to look at one post with same concerns than perusing through 20. Edited October 8, 2014 by groundhog47 Share this post Link to post Share on other sites
groundhog47 448 #18 Posted October 8, 2014 (edited) Mike and jeremi, it kinda worked and I reaped another couple loads. 1st pic set up sim to Mike's suggestion (except used 4ea- 2x stock), 2nd readjusred hitch to 2r and top hole on clevis pull bar + added wheel weights, 3rdlevel with tip on ground and heel about 1-1 1/2" high, 4th plowing but over some some fresh but flipped over a nice chunk,5th a mess, 6th and 7th what I'm trying to accomplish. Only a couple dozen wheel barrows to go Pics 3 and 4 out of sync with post>>> Edited October 8, 2014 by groundhog47 Share this post Link to post Share on other sites
squonk 48,036 #19 Posted October 8, 2014 Plowing sod is the toughest. One all the grass is gone and you're plowing just the dirt, it will be a breeze. Share this post Link to post Share on other sites
jeremi3210 752 #20 Posted October 8, 2014 Also if your plow is rusty it won't work real good. Share this post Link to post Share on other sites
