brandon701 23 #1 Posted October 4, 2014 Friend of mine has a 864 that I'm trying to get running better. Clean the carb out etc. after that the thing ran great but now it only idles it doesn't seem to accelerate. Made some adjustments on the carb with no change Anybody with ideas let me know Thanks Share this post Link to post Share on other sites
WH nut 553 #2 Posted October 4, 2014 Does it try to run better with a little choke? Share this post Link to post Share on other sites
Racinbob 12,204 #3 Posted October 4, 2014 Check the fuel filter and if there's a fine screen in the tank. Also make sure the fuel lines are good. Share this post Link to post Share on other sites
brandon701 23 #4 Posted October 4, 2014 Fuel filter and fuel lines are new. I will have to check the little screen in the tank. When I give it a little choke it quits. Share this post Link to post Share on other sites
Racinbob 12,204 #5 Posted October 4, 2014 OK. Check that screen. When it does what yours is doing it's usually getting starved for fuel. Choking it reduces the air intake to fool it into thinking it's getting enough. Share this post Link to post Share on other sites
brandon701 23 #6 Posted October 5, 2014 Alright I'll check the screen. Thanks Share this post Link to post Share on other sites
Racinbob 12,204 #7 Posted October 5, 2014 If you don't have a screen or it's clean check the fuel output from the fuel pump. If that's good I'd say it has to be in the carb. Did you just clean it or totally rebuild it making sure the float was set properly? Share this post Link to post Share on other sites
bmsgaffer 2,054 #8 Posted October 6, 2014 Fuel filter and fuel lines are new. I will have to check the little screen in the tank. When I give it a little choke it quits. OK. Check that screen. When it does what yours is doing it's usually getting starved for fuel. Choking it reduces the air intake to fool it into thinking it's getting enough. Bob, I think when he said "When I give it a little choke it quits." I think he means it stalls... That is how I read it at least? 1 Share this post Link to post Share on other sites
Racinbob 12,204 #9 Posted October 6, 2014 Ahh yes Brandon. I read it again and I see how it could be interpreted that way. I was thinking it was like when you start running out of fuel 100 yards from the gas can and a little choke will get you a few feet closer. Brandon701, could you verify please? Share this post Link to post Share on other sites
WH nut 553 #10 Posted October 6, 2014 If it quits running with choke you are over fueling Share this post Link to post Share on other sites
