DadsToyMomsHeadache 3 #1 Posted October 3, 2014 why does it only wanna start and run this wa Share this post Link to post Share on other sites
DadsToyMomsHeadache 3 #2 Posted October 3, 2014 http://youtu.be/oIXYrahLyj4qu Share this post Link to post Share on other sites
Desko 624 #3 Posted October 3, 2014 Well I can't watch the video but what exactly is it doing and welcome to red square glad to have you here Share this post Link to post Share on other sites
DadsToyMomsHeadache 3 #4 Posted October 3, 2014 it will only start up when I hold the spark plug wire to the side of the spark plug and jump aras soon as I put the wire on the plug it want to stall I take it back off and it idles back up again Share this post Link to post Share on other sites
Desko 624 #5 Posted October 3, 2014 Its sounds like the electrode is bad in the plug try a new plug and see if that helps 1 Share this post Link to post Share on other sites
DadsToyMomsHeadache 3 #6 Posted October 3, 2014 ok thanks I'll try it when I get home today Share this post Link to post Share on other sites
Geno 1,929 #7 Posted October 3, 2014 Hello and I can't get the video to work either. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,706 #9 Posted October 3, 2014 For some reason your plug will not supply sufficient spark to ignite the fuel with the normal high voltage from the coil. When you increase the spark gap that increases the coil output voltage so the plug fires. Problem with that is the higher voltage may be more than the plug wire insulation or the coil insulation can withstand and it burns a hole in the insulation. Then the spark takes the path of least restriction. Garry 1 Share this post Link to post Share on other sites
Geno 1,929 #10 Posted October 3, 2014 (edited) That's where to start. Edited October 3, 2014 by Geno Share this post Link to post Share on other sites
Ethan and Randies horses 65 #11 Posted October 3, 2014 try new wire or new points Share this post Link to post Share on other sites
DadsToyMomsHeadache 3 #12 Posted October 3, 2014 ended up being spark plug thank you too everyone who gave me advice appreciate it Share this post Link to post Share on other sites
Coadster32 793 #13 Posted October 4, 2014 Glad it's fixed. Never seen that before. (although, might have fixed it in the past, and just never knew it) Share this post Link to post Share on other sites
