Retired Wrencher 6,172 #1 Posted September 28, 2014 I have a commando 6 that I have trying get running as a hobby or a learning tool about Tecumseh engines.. I put all new under the fly wheel. tried to see if I have spark. as soon as I turned the key there was smoke coming from under the flywheel so seem obvious that there was something wrong with the mag system when I bought it. is there a way to test the mag to see if it is bad. Also I looked in the manual there is a few to choose from all are 12v/3amp. I need the one that has the rectifier sys on it. I would like to find a used one. I do not want to a lot of $$$$$ in this it is just something to fool around with. Any info would be helpful. Gary B...... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #2 Posted September 29, 2014 See if there is anything in this manual that would help Garry 1 Share this post Link to post Share on other sites
Retired Wrencher 6,172 #3 Posted September 30, 2014 See if there is anything in this manual that would help Garry thanks I will look it up Share this post Link to post Share on other sites
WH nut 553 #4 Posted October 1, 2014 If you had smoke from the flywheel area you hooked up your mag to 12v. Its shot now that the smoke has been let out Share this post Link to post Share on other sites
