Fordiesel69 271 #1 Posted September 28, 2014 Got a nice 312-8 with a magnum m12 and it had 1161 hrs on it. Was an oil burner whenever the gov had to open up, or whenever you accelerated. It would never smoke once it leveled off. Tore it down and found the rings to be razor sharp, the piston slightly carbon damaged on the top quench area, and the rings were absolutely shot. So I cleaned it up and slapped a set of stens rings on it. The smoke is 80% reduced, but it still smoked a tad when you throttle it, or hit heavy grass and the gov has to open up. I have 1.5 hrs on the new rings, will it take much longer? Reason being it the rings I got on the cheap ebay kits, and some of the NOS rings I have obtained on ebay work 100% right off the bat. Never a need for a break in before they will stop smoking. I honed with a 3 blade rigid hone, not a bottle brush / dingle ball hone. Share this post Link to post Share on other sites
Pickle 43 #2 Posted September 29, 2014 What was the piston to cylinder running clearance? What were the ring end gap measurements? What is the valve guide clearance measurements? The engine should not smoke after proper ring installation if the above clearances are correct. Share this post Link to post Share on other sites
Fordiesel69 271 #3 Posted September 29, 2014 Valve guides were tight, very tight actually which was quite surprising. The cylinder to piston clearance was .001 away from max, so it will definatly need bored once it hits 2000 hrs. Ring gaps were in the middle of the spec in my k series manual. I don;t have a magnum manual, but they are the same anyways. Top and second were .018 gap, and oil was .014 gaps. I have a 5 arce lot to cut soon, so I hope I can rack up some hrs on it. The rings should seat by that time or I will send them back for a refund. I did a M12 and M14 over last winter, and used NOS rings and the cylinders were also about the same. Zero smoke from those. Share this post Link to post Share on other sites
prondzy 3,889 #4 Posted September 29, 2014 you checked ring end gap and that's good, .010-.020 if im correct is spec, so it sounds like you are on the outer edges of the spec. When you measured for out of round of the cylinder how many places up and down the cylinder bore did you measure? and what was the difference between the pin sides of the bore and the thrust sides of the bore? The cylinder will wear greater at the top of the cylinder than the bottom of the cylinder that is why there usually is a spec for old bore and a new oversized bore. If you are only burning on the throttle up side, and governor kicking in I guess that little bit of burn isn't much to worry about for a set of rings cheapies or OEM. Share this post Link to post Share on other sites
Fordiesel69 271 #5 Posted September 29, 2014 (edited) Top and middle on the thrust sides of the wall. I used snap guages and calipers. Im sure a set of mics would be more accurate... Old rings were NOT staggered correctly. The new ones were. Edited September 29, 2014 by Fordiesel69 Share this post Link to post Share on other sites
oldredrider 2,553 #6 Posted September 29, 2014 Personally, I wouldn't worry about a little smoke until the rings seat. You know that it will be needing a rebore "soon" so roll with it until you decide to rebore. I don't think the rings are to blame. Share this post Link to post Share on other sites
oldredrider 2,553 #7 Posted September 29, 2014 On another note, I know you are using Rotella. Good oil...may take longer for the rings to seat since you are on the outer fringes of this bore. Share this post Link to post Share on other sites
rmaynard 16,837 #8 Posted September 29, 2014 What kind of rings were installed? Chrome or non-chrome. Chrome rings take longer to seat than non-chrome. Share this post Link to post Share on other sites
Fordiesel69 271 #9 Posted September 29, 2014 On another note, I know you are using Rotella. Good oil...may take longer for the rings to seat since you are on the outer fringes of this bore. I only use the rotella t1 sae 30 in my 515 hrs 312 and 255 hr 314, the rest gets wolfs head sae 30 until I run out. I used it in the engine in question for break in purposes. I think stens uses chrome. I am not certain. Share this post Link to post Share on other sites
Coadster32 793 #10 Posted September 29, 2014 What kind of rings were installed? Chrome or non-chrome. Chrome rings take longer to seat than non-chrome. X2 on this. Chrome plating is pretty hard, and will take a little while to wear, "seat" itself. I was going to mention about the orientation of the ring end gaps, but seems as though you have that covered as well. Share this post Link to post Share on other sites
specialwheelhorse 174 #11 Posted September 29, 2014 I see you are a ford man so I just happen to have a ford garden tractor Manuel For tractors with Koehler engines and in the rebuild section it recommends 5 Five hours run in time to properly seat rings. And according to kohlers Manuel the first half hour should be run in with 20 non d under some load then drained and another 4 1/2 hours with 30 non d then drain again and a fresh batch of 30 non d then should be good to go I got about two dozen out here with that treatment and non smoke with non chrome And chrome rings. 1 Share this post Link to post Share on other sites
Fordiesel69 271 #12 Posted September 30, 2014 I see you are a ford man so I just happen to have a ford garden tractor Manuel For tractors with Koehler engines and in the rebuild section it recommends 5 Five hours run in time to properly seat rings. And according to kohlers Manuel the first half hour should be run in with 20 non d under some load then drained and another 4 1/2 hours with 30 non d then drain again and a fresh batch of 30 non d then should be good to go I got about two dozen out here with that treatment and non smoke with non chrome And chrome rings. The only issue I have with that statement is that non d oil today is crap. I cannot find it in my area except at walmart and it has API service SA. This will not work in a kohler. The second issue is kohler has officially changed to recommend detergent oils across the board. In an old dirty sludged engine, this indeed would be instant death. But with this engine the internals were sprayed down and the oil pan was warshed. So it should still be ok should the proper intervals be maintained. I assume the rings are just taking some time, and frankly I have not been able to induce a heavy load on it. I have mowed with it and lugged it down, but not the way I want to. Share this post Link to post Share on other sites
Fordiesel69 271 #13 Posted October 3, 2014 Got 4 hrs on it now, its getting better. It does have a dirty exhaust when accelerating, but it is not blue anymore. What I did find is that this magnum has the more rare (older) Carter style carb on it, which are typically not as emission friendly. I am used to running the walbro models on the magnums which are significantly cleaner. I may choose to swap over a walbro from one of my spare M12's to try it out. Share this post Link to post Share on other sites
oldredrider 2,553 #14 Posted October 3, 2014 Generally, I believe they don't break in until about 8 hours. Give it a few more then try the carb swap. Share this post Link to post Share on other sites
Fordiesel69 271 #15 Posted October 3, 2014 If we let up on the rain soon, I will be able to do 4-5 acres which is about 4-5 hrs total with trimming around the stuff. 1 Share this post Link to post Share on other sites
