KyBlue 655 #1 Posted September 28, 2014 This is the deck that came with the 418A. I pulled it off and put it on the B when the Kohler was found to be critically wounded on the 418A. It cut like Poo ... The blades weren't level and you could watch the shell flex when I picked up on the lift. Not good! Since it's the end of summer It's time to redo it. Being as everybody loves pictures ... I'll do my best to document what I do. I pulled the Lift Linkages and the wheels off tonight, in order to search for, and mark any/all cracks and damage. Four Cracks, One WTF area that is going to have to be totally cut out and patched, and a tiny pinhole of rust. I haven't Stripped the inderside yet, but I suspect a couple of the baffles are going to need to work too. I'll be pulling the Spindles off, and getting the rest of the deck stripped soon, then I'm going to turn the media blaster on it. Once the Cracks and em, prior damage repaired It'll get Primed and Painted. 1 Share this post Link to post Share on other sites
KyBlue 655 #2 Posted July 25, 2015 (edited) A bit of a update for you ... rust repair is done! however when I put the shell back together I noticed the blades were uneven (the cause of it cutting like poo) ... after scraping away the grass and debris around the spindles ... I found half missing spindles! Two of the four bolts were gone on one, and the other only only had three...Pics are coming Edited July 25, 2015 by KyBlue Share this post Link to post Share on other sites
PaulC 342 #4 Posted July 25, 2015 Unfortunately this is pretty common stuff but fortunately your deck shell really isn't that bad. I have a couple spindles housings messed up like yours on a deck I'm fixing. Mine still have about half a hole and I was thinking of going with a longer bolt and putting a nut on the back? Spindle housings are not cheap!! Good luck with your repairs and keep the pics coming. Share this post Link to post Share on other sites
bmsgaffer 2,054 #5 Posted July 26, 2015 Thanks for the update Blue.I have had a couple spindle housings rot away like that and the grass makes them look whole!Looking forward to following progress! Share this post Link to post Share on other sites
slammer302 2,156 #6 Posted July 26, 2015 I have a good housing i would sale if you are intrested KyBlue Share this post Link to post Share on other sites
KyBlue 655 #7 Posted July 26, 2015 Already have the housings - I needed two so I reached out to someone who I knew would have them... sadly now I'm waiting for two bearingsI did find quite a few cracks in the Shell under the pullies. Ground them out a bit and welded them up. More pics when my bearings come in.6203-RS1 if anybody needs the # (the 6203-2RS won't fit so beware) Share this post Link to post Share on other sites
can whlvr 994 #8 Posted July 30, 2015 the shells of the mower decks are a constant repair issue,and they do wear out,thats why a lot of people get rid or their wheelhorse,they can buy a new cheapo lawn tractor cheaper than a deck when priced at dealer,i just picked up a c160 because of this heres a pic of my bought from new 42 sd ,I had to replace the whole top of the deck,but its so smooth when running because I used 5/16 plate, Share this post Link to post Share on other sites
