Triple400 13 #51 Posted October 10, 2014 Not sure about 3 treckies, but once i originally built the belt system linked them all together, it was then I found out the it was not gonna start. Starting 3 small engines was way too much to start with the rope pull or even pulling on 2 of the rope pulls at once. It was neccesary to get one engine(pony motor) to start, then engage a lever to start the other 2. The one 5hp engine does struggle for a bit to start the other 2. Once I finish this tractor, I will have a electric start to start the pony motor, which will them sart the other 2. so starting is alittle bit of a process, but seems to work just fine so far 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #52 Posted October 10, 2014 I would've had a video of the start up procedure had I known you were going to be so generous by putting fire in the hole for us. Half expected you to be bent out of shape because we were all over your tractor when you walked up. Actually wanted to apologize for our behavior, but really...you should take it as a compliment. Your Tri-Po 400 is an awesome build Ethan. Share this post Link to post Share on other sites
jetmandan 29 #53 Posted October 10, 2014 Sweet ride! Perfect job on the belt guard, even the primer on edge looks great Now take those too shiny & new looing engine cowlings, sand blast a little and plug them with a few bullet holes for effect Dan Share this post Link to post Share on other sites
Firpo701 408 #54 Posted October 10, 2014 Do you really think you can get three Teckies running at the same time. You might need a 20 Onan for a starter.And that's when the fight broke out!! Lol! :laughing-rolling: Share this post Link to post Share on other sites
Triple400 13 #55 Posted October 10, 2014 I would've had a video of the start up procedure had I known you were going to be so generous by putting fire in the hole for us. Half expected you to be bent out of shape because we were all over your tractor when you walked up. Actually wanted to apologize for our behavior, but really...you should take it as a compliment. Your Tri-Po 400 is an awesome build Ethan. i'm very honored amc rules. And it is a total compliment when people are smiling looking at my work. Thank you again for showen interest, taking/putting pictures on this site. Once again very honored and happy your were interested and looking at my tractor, and no need for a apologize 1 Share this post Link to post Share on other sites
