BairleaFarm
c160 is messed up again
BairleaFarm
The c160 drive pulley came loose again :banghead: I will be putting new set screws in it with locktite this time. In the 15min i test drove it after putting the starter on it the inside of the drive belt wos tore up. Im hoping that pulley moving was the cause. Maybe hitting that metal piece inside the shield. The tractor has potential i feel it.
MaineDad
I feel your pain my C-160 Brother from another Mother. Together will get these bleeping C-160's running sweet :banghead:
refracman
David,
After running in the set screw and tighting run a second down that will lock the first one in place also.
And you can't beat a good 160 when it comes time to doin the chores :banghead:
BairleaFarm
good idea - it wont mess up the bottom one?
kj4kicks
make sure the belt is on the top side of the belt guide that looks like this /-\ inside of the belt guard.
BairleaFarm
I will, I used those blue belts from TSC - Looks like alint trap threw up all over the Wheel Horse.
kj4kicks
...and there's another reason to use OEM belts, especially for drive belts.
BairleaFarm
If i only had a dealer near me. :horseplay: i need to check out the one by work. Whats the average cost on them? anyone know?
rustbucket
i use TSC blue belts and dunt have the lint trap issue on any of my machines useing those belts.
WheelHorse_of_course
David, they should be hardened steel, so the bottom one shouldn't get mashed.
By the way, verify that with the set screws loose there is no slop (wobble) and also verify that there is no rotation rotational slop.
If there is you should replace the key at the very least. Probably the pulley too.
Any idea how long it was run loose before you discovered it?
Best of luck :banghead: :USA:
BairleaFarm
not initially. ive only run it an hour or so since i last tightened it
linen beige
David, you might check out Eastland Power Sports. 1230 Winchester road,Lexington. 859-226-9992. They are a Toro dealer. I've bought some things from them. They do seem to be heading towards sport bikes instead of tractors though. They're just "inside" New Circle rd., right across from Eastland shopping center where Harbor Freight is.
I've had good luck dealing with Central Equipment, 791 Red Mile Road. Lexington. 859-253-2611. They aren't a Toro dealer, but because they run one of the busiest repair shops around, they stock a lot of parts for a lot of machines. One of the parts guys grew up in his dad's Wheel Horse dealership in Lexington (now closed) and will try his best to get you what you need. I recently asked for a set of points for a Kohler K-241 and when I read him the spec # he recognized it as Wheel Horse and nearly talked my leg off. They have about the best prices around too.
I know you may not come to Lexington often, I don't blame you for staying out of the traffic, but it really isn't that far of a drive.
If you don't mind a little drive, Hill's in Bardstown is a Toro dealer that started out as a Wheel Horse place many years ago. I've not been in their shop, but my dad deals with them and seems to be very impressed.
BairleaFarm
:banghead: except everyday. I work at supier van and mobility over there by sams. I drive by that dealer almost daily.
linen beige
You're closer than I am then! I don't know what their hours are, but I don't think they're open on saturdays.
Central equipment is open from 7A.M. to at least 5 P.M. and until noon on saturday. I need to get in there for a couple small things, I'll ask about belts.
KyBlue
From What ive been told, The John Deere Dealer here in town is a Toro Dealer... our Local (old) WH dealer, sent me down there when I needed to order some parts for my B...
Of Course, If I dont wanna deal with either of them you can always go thru places like PartsTree or Even Directly from Toro..While you have to wait for the parts to get shipped to ya... When YOU get the Money...Order a Spare Set of Common use things, Plug, Belts, Points, Etc Etc etc - I keep Spare Filters, Belt, Hoses, etc etc for all my vehicles, and as soon as I get the spare $$$ Ill do the same thing for the WH... Cause Ill be needing a Drive Belt too, and My Drive Pulley is loose...Still on the shaft okay, but its walking back and forth.
Sry Im Rambling again! Hahaha
BairleaFarm
If Bevins Tractor is a dealer that would be sweet. ve known The Owner for Years.
KyBlue
bevins... Yeah thats the one...Couldnt think of the name!
linen beige
David, I checked at Central Equipment this morning. They don't stock Toro and recommended Bevins in G'town over Eastland power sports. They said the difference in price and service would most likely be worth the drive for me. And the drive would be even less for you.
BairleaFarm
Sweet Bevins bleeds green and yellow. I can belive they might have toro stuff. Ill call them monday
BairleaFarm
Shes up and going at this point in time. The belt does in deed stop when the parking brake is set. The hydro still acts funny I think. The heads were stripped out a bit which I think may have prevented me from tightening them does. New set screws and we are good to go for the time being.
KyBlue
Least ya got it goin again. Did ya give bevins a call??
BairleaFarm
Not yet
