BairleaFarm 340 #1 Posted October 11, 2008 The c160 drive pulley came loose again I will be putting new set screws in it with locktite this time. In the 15min i test drove it after putting the starter on it the inside of the drive belt wos tore up. Im hoping that pulley moving was the cause. Maybe hitting that metal piece inside the shield. The tractor has potential i feel it. Share this post Link to post Share on other sites
MaineDad 87 #2 Posted October 11, 2008 I feel your pain my C-160 Brother from another Mother. Together will get these bleeping C-160's running sweet :banghead: Share this post Link to post Share on other sites
refracman 167 #3 Posted October 11, 2008 David, After running in the set screw and tighting run a second down that will lock the first one in place also. And you can't beat a good 160 when it comes time to doin the chores :banghead: Share this post Link to post Share on other sites
BairleaFarm 340 #4 Posted October 11, 2008 After running in the set screw and tighting run a second down that will lock the first one in place also. good idea - it wont mess up the bottom one? Share this post Link to post Share on other sites
kj4kicks 154 #5 Posted October 11, 2008 make sure the belt is on the top side of the belt guide that looks like this /-\ inside of the belt guard. Share this post Link to post Share on other sites
BairleaFarm 340 #6 Posted October 11, 2008 I will, I used those blue belts from TSC - Looks like alint trap threw up all over the Wheel Horse. Share this post Link to post Share on other sites
kj4kicks 154 #7 Posted October 11, 2008 ...and there's another reason to use OEM belts, especially for drive belts. Share this post Link to post Share on other sites
BairleaFarm 340 #8 Posted October 11, 2008 If i only had a dealer near me. :horseplay: i need to check out the one by work. Whats the average cost on them? anyone know? Share this post Link to post Share on other sites
rustbucket 4 #9 Posted October 11, 2008 i use TSC blue belts and dunt have the lint trap issue on any of my machines useing those belts. Share this post Link to post Share on other sites
WheelHorse_of_course 99 #10 Posted October 11, 2008 David, they should be hardened steel, so the bottom one shouldn't get mashed. By the way, verify that with the set screws loose there is no slop (wobble) and also verify that there is no rotation rotational slop. If there is you should replace the key at the very least. Probably the pulley too. Any idea how long it was run loose before you discovered it? Best of luck :USA: Share this post Link to post Share on other sites
BairleaFarm 340 #11 Posted October 11, 2008 not initially. ive only run it an hour or so since i last tightened it Share this post Link to post Share on other sites
linen beige 15 #12 Posted October 11, 2008 If i only had a dealer near me. David, you might check out Eastland Power Sports. 1230 Winchester road,Lexington. 859-226-9992. They are a Toro dealer. I've bought some things from them. They do seem to be heading towards sport bikes instead of tractors though. They're just "inside" New Circle rd., right across from Eastland shopping center where Harbor Freight is. I've had good luck dealing with Central Equipment, 791 Red Mile Road. Lexington. 859-253-2611. They aren't a Toro dealer, but because they run one of the busiest repair shops around, they stock a lot of parts for a lot of machines. One of the parts guys grew up in his dad's Wheel Horse dealership in Lexington (now closed) and will try his best to get you what you need. I recently asked for a set of points for a Kohler K-241 and when I read him the spec # he recognized it as Wheel Horse and nearly talked my leg off. They have about the best prices around too. I know you may not come to Lexington often, I don't blame you for staying out of the traffic, but it really isn't that far of a drive. If you don't mind a little drive, Hill's in Bardstown is a Toro dealer that started out as a Wheel Horse place many years ago. I've not been in their shop, but my dad deals with them and seems to be very impressed. Share this post Link to post Share on other sites
BairleaFarm 340 #13 Posted October 11, 2008 I know you may not come to Lexington often except everyday. I work at supier van and mobility over there by sams. I drive by that dealer almost daily. Share this post Link to post Share on other sites
linen beige 15 #14 Posted October 11, 2008 except everyday. I work at supier van and mobility over there by sams. I drive by that dealer almost daily. You're closer than I am then! I don't know what their hours are, but I don't think they're open on saturdays. Central equipment is open from 7A.M. to at least 5 P.M. and until noon on saturday. I need to get in there for a couple small things, I'll ask about belts. Share this post Link to post Share on other sites
KyBlue 655 #15 Posted October 11, 2008 From What ive been told, The John Deere Dealer here in town is a Toro Dealer... our Local (old) WH dealer, sent me down there when I needed to order some parts for my B... Of Course, If I dont wanna deal with either of them you can always go thru places like PartsTree or Even Directly from Toro..While you have to wait for the parts to get shipped to ya... When YOU get the Money...Order a Spare Set of Common use things, Plug, Belts, Points, Etc Etc etc - I keep Spare Filters, Belt, Hoses, etc etc for all my vehicles, and as soon as I get the spare $$$ Ill do the same thing for the WH... Cause Ill be needing a Drive Belt too, and My Drive Pulley is loose...Still on the shaft okay, but its walking back and forth. Sry Im Rambling again! Hahaha Share this post Link to post Share on other sites
BairleaFarm 340 #16 Posted October 11, 2008 If Bevins Tractor is a dealer that would be sweet. ve known The Owner for Years. Share this post Link to post Share on other sites
KyBlue 655 #17 Posted October 11, 2008 bevins... Yeah thats the one...Couldnt think of the name! Share this post Link to post Share on other sites
linen beige 15 #18 Posted October 11, 2008 David, I checked at Central Equipment this morning. They don't stock Toro and recommended Bevins in G'town over Eastland power sports. They said the difference in price and service would most likely be worth the drive for me. And the drive would be even less for you. Share this post Link to post Share on other sites
BairleaFarm 340 #19 Posted October 12, 2008 Sweet Bevins bleeds green and yellow. I can belive they might have toro stuff. Ill call them monday Share this post Link to post Share on other sites
BairleaFarm 340 #20 Posted October 14, 2008 Shes up and going at this point in time. The belt does in deed stop when the parking brake is set. The hydro still acts funny I think. The heads were stripped out a bit which I think may have prevented me from tightening them does. New set screws and we are good to go for the time being. Share this post Link to post Share on other sites
KyBlue 655 #21 Posted October 14, 2008 Least ya got it goin again. Did ya give bevins a call?? Share this post Link to post Share on other sites
BairleaFarm 340 #22 Posted October 14, 2008 Not yet Share this post Link to post Share on other sites
