tom h.hill 10 #1 Posted September 26, 2014 well i bought a new carb,after market fuel pump,new plug and points an condensor.figured out the wiring.its running but at low rpms ansorta high rpms i cant seem to get it to smooth out.i try adjusting the carb an thepopping almost goes away but not fully.oh yeah it is hard to get started.i get on it take a couple of laps around the yard get back to the garage put in nutral an then it just quits altogether.an then wont start foe awile.to get it started i have to hold my hand over the mouth of the carb.i noticed a couple of times when the idle was up the battery terminal on the voltage regulator the conection was sparking.WHATCHA THINK. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #2 Posted September 26, 2014 Tom What model tractor is this and what engine? Garry Share this post Link to post Share on other sites
tom h.hill 10 #3 Posted September 27, 2014 sorry about that.its my awsome 1054 10hp. Share this post Link to post Share on other sites
rmaynard 16,700 #4 Posted September 27, 2014 Is the carburetor a new OEM carburetor, a new after-market carburetor, or a new to you used carburetor? Tighten all of your electrical connections if they are sparking. Share this post Link to post Share on other sites
tom h.hill 10 #5 Posted September 27, 2014 (edited) new new carb.im in the house now but im pretty sure its a carter. Edited September 27, 2014 by tom h.hill Share this post Link to post Share on other sites
oldredrider 2,553 #6 Posted September 27, 2014 Double check your condensor. Make sure it is hooked to the - post on the coil and is mounted to a good ground. Share this post Link to post Share on other sites
tom h.hill 10 #7 Posted September 27, 2014 im heading out an check that now.thanks Share this post Link to post Share on other sites
KyBlue 655 #8 Posted September 27, 2014 Keep us posted! Share this post Link to post Share on other sites
stevasaurus 23,517 #9 Posted September 27, 2014 The points should be set at .020, maybe try the gap at .018. The gap controls the timing and sometimes on these old machines the smaller gap works better. Share this post Link to post Share on other sites
tom h.hill 10 #10 Posted September 27, 2014 well im redoing everything fromthe points an condensor.making the choke cable an lever glide back an forth easyier.checkin grounds thank you all for your input.ill be intouch.thanks again Share this post Link to post Share on other sites
tom h.hill 10 #11 Posted September 29, 2014 went out worked on it most of sunday checked elec conections and grounds.thier good.rechecked points gap 18 condensor good ground .reran choke cable now it operates nice an smooth.im getting gas and spark and it still wont start.the only way i can start it is by giving it a shot of either an then it only stays running for a few seconds.oyeah i adjusted carb.turned both screws in an backed them out 1 1/4 turn an then try ajusting them from there.no luck.cant figure out what aint right.s/g was just bebuilt new voltage reg.no clue Share this post Link to post Share on other sites
stevasaurus 23,517 #12 Posted September 29, 2014 (edited) Disconnect the line going from the fuel pump to the carb and see if gas spurts out when cranking the engine. I chased a fuel problem like what you are describing all the way back to the tank one day. There was a white spider in the tank blocking the fuel line just enough to make it run like yours. Flushed out the spider and it ran great (after readjusting the carb, because now it was getting gas). I know you said the carb was new, but this only takes a second to check. Take out the adjustment screw that is on top of the carb. There is a small hole in the shaft of that screw near the point. Take some carb cleaner and a piece of wire that will fit in the hole and make sure it is not clogged. This happened on my B-100. Edited September 29, 2014 by stevasaurus Share this post Link to post Share on other sites
rmaynard 16,700 #13 Posted September 29, 2014 Hmm...have you checked the gas cap to be sure that the vent is open? 3 Share this post Link to post Share on other sites
WH nut 553 #14 Posted September 29, 2014 How was the gasket carb to block? Share this post Link to post Share on other sites
Firpo701 407 #15 Posted September 29, 2014 went out worked on it most of sunday checked elec conections and grounds.thier good.rechecked points gap 18 condensor good ground .reran choke cable now it operates nice an smooth.im getting gas and spark and it still wont start.the only way i can start it is by giving it a shot of either an then it only stays running for a few seconds.oyeah i adjusted carb.turned both screws in an backed them out 1 1/4 turn an then try ajusting them from there.no luck.cant figure out what aint right.s/g was just bebuilt new voltage reg.no clueI always back the adjustments out 2 1/2 turns and then adjust... 1 Share this post Link to post Share on other sites
tom h.hill 10 #16 Posted September 29, 2014 well let me tell ya.backed out the screw on top cleaned it.put it back.disconnect fuel line from carb turned it over not squirtin nothin out from fuel pump.now its a straight line to the inline fuel filter an then straigh line to the glass bowl attatched to the gas tank.well gavity should let the gas pour out in a way.but nothin.so im going to eliminate the glass bowl i got a new inline filter and new line.back to fuel pump an we should be good.thank you for pointing me in the right direction.tomorrow after work you no what ill be doing.thankyou very much. ill get back to ya once its all hooked up.seeya Share this post Link to post Share on other sites
tom h.hill 10 #17 Posted September 30, 2014 no good.need to get another fuel pump.this is drivin me crazy.when i crank it over the gas is not squirting out the fuel pump.the origianl pump was metal this replacement one is plastic.anyone no where i can find a metal one? Share this post Link to post Share on other sites
stevasaurus 23,517 #18 Posted September 30, 2014 Do you have the old one?? You can take it apart and clean it. It has 2 metal balls in it...one lets gas in the pump from the tank side and the other keeps gas from draining back down from the carb. I am not sure, but is it possible to mount your new one upside down? Sorry, I had to ask. Share this post Link to post Share on other sites
stevasaurus 23,517 #19 Posted September 30, 2014 Check out section 6 in this manual... https://docs.google.com/file/d/0B0skuszqFgg-YTk0ODdjMmYtMjQwMi00NDQ0LTk1YmItZGY4ZmEzODI2MDNk/edit?pli=1 Share this post Link to post Share on other sites
Martin 2,133 #20 Posted September 30, 2014 Did you pressurize the tank to make sure no air is in the line between tank and fuel pump. If you have any air in there it will make it hard for the pump to be able to move gas in the line when cranking. Being a 1054 I would use a clean toilet plunger or similar and make sure you get the line full of gas. Sent from my iPhone using Tapatalk 1 Share this post Link to post Share on other sites
rmaynard 16,700 #21 Posted September 30, 2014 If you are getting no flow of gas from the glass bowl when you disconnect the inlet tube from the pump, another pump probably isn't going to help. You need to find out why the gas is not flowing out of the tank by gravity 2 Share this post Link to post Share on other sites
tom h.hill 10 #22 Posted October 2, 2014 i did everything everyone suggested.nothin.so i pulled the fuel pump off again turned it over an heard something rattle inside of it.so i open the pump up shoock it an out of the arm there came out this crab claw piece an on the the ends of it you could see it broke off the end of the arm cause it was what fastened the plunger part of the pump to the arm.so now i got to get another pump.sure dont want another plastic one.i saw online a couple of origanal ones but they want way way to much money an then you dont no if its any good .or if it works you dont no how long it will last.ya no what i mean.thanks everyone again. 1 Share this post Link to post Share on other sites
rmaynard 16,700 #23 Posted October 2, 2014 I've been using a plastic pump for about six years on my B-100. No problems. If the pump was purchased new, I'd return it. Buying a used pump is risky unless the seller is willing to guarantee it with full return privileges including shipping. Share this post Link to post Share on other sites
stevasaurus 23,517 #24 Posted October 2, 2014 Excellent, Looks like you found the problem. Share this post Link to post Share on other sites
tom h.hill 10 #25 Posted October 2, 2014 (edited) Well until I find a good pump. I saw this guy make up a different way using a Briggs an Stratton fuel pump. It looked like he new what he was doing. An it worked. This is only temporary.ya it sure does work.now i just need to add a gasket to to piece i made up.man what a difference in running getting a good constint flow of gas.rerun all the lines and secure everything an thats one problem done .i made a stainlees steel air breather similar to one of the pics i saw in the gallery of photos.that bolted up perfect to the carb.thanks for your input everyone. Edited October 4, 2014 by tom h.hill Share this post Link to post Share on other sites
