fishingstararlake 1 #1 Posted September 23, 2014 my 520 has started to start hard. I took the gas line off after the fuel pump and the gas flows out of it but not a lot. shouldn't it pulse out of it? When working on a snowmobile's vacuum fuel pump the will shoot out up to 3 to 4 feet should I expect the same? thanks Dan Share this post Link to post Share on other sites
Geno 1,929 #2 Posted September 23, 2014 Yep, it should shoot out several feet. 1 Share this post Link to post Share on other sites
Mr.phil 0 #3 Posted September 26, 2014 My 318-8 that I bought new in 1991 also needs a fuel pump. For my application the best price on a new Kohler replacement was from Pats Small Engine. Share this post Link to post Share on other sites
fishingstararlake 1 #4 Posted September 28, 2014 does anybody have a part number for a rebuild kit for 149-2178-01 I have not found a kit for it just a new pump thanks Dan Share this post Link to post Share on other sites
boomers_influence 106 #5 Posted September 28, 2014 fish no kits are ava. for these pumps. thank you boomer ( the used onan engine parts guy ) Share this post Link to post Share on other sites
Mr.phil 0 #6 Posted October 12, 2014 New fuel pump solved the starting problem on Kohler M12. The new pump had press on fittings and the Specs. Called for threaded fittings. But it worked well, only problem was having to purchase a large heavy duty snap-ring pliers for a large snap-ring used as a instillation tool. Next project is a replacement exhaust system for the Kohler M12, the muffler is no longer available. Share this post Link to post Share on other sites
fishingstararlake 1 #7 Posted October 24, 2014 (edited) I replaced the fuel pump still has week flow. I'm going to replace all the lines. how do I get at the vacuum line? where on the block does the vacuum line hook up? whats up with the line? Edited October 24, 2014 by fishingstararlake Share this post Link to post Share on other sites
fishingstararlake 1 #8 Posted October 24, 2014 what is the small line coming from the air cleaner? I found that it is unhooked. Share this post Link to post Share on other sites
boomers_influence 106 #9 Posted October 24, 2014 sir can you post a pic? thank you. boomer Share this post Link to post Share on other sites
fishingstararlake 1 #10 Posted October 25, 2014 I found that it is the line for a dirty air filter Share this post Link to post Share on other sites
