GrumpyOldBastige 1 #1 Posted September 22, 2014 (edited) Wire running from ignition switch to starter solenoid: the 25 amp inline fuse keeps blowing whenever I turn the key to START. I double-checked the wiring, replaced the fuse, and pop goes the fuse. Tractor won't even turn over; no juice going to the solenoid. edit- I forgot to mention that, when I disengaged the deck after mowing, the tractor abruptly died. That led to all of this happening. Since that- replace fuse, hit the key, pop. rinse and repeat edit 2- I hear both switches when I engage the deck but only one when I disengage, does that mean anything? Ideas? Edited September 22, 2014 by GrumpyOldBastige Share this post Link to post Share on other sites
slammer302 2,157 #2 Posted September 22, 2014 I had the same problem before end up being a bad ignition switch Share this post Link to post Share on other sites
chazm 413 #3 Posted September 22, 2014 May want to pull battery & check wiring... had issues with wires rubbing on my 314 Share this post Link to post Share on other sites
slammer302 2,157 #4 Posted September 22, 2014 When you unplug the ignition switch I bet one of the prongs is all burt and corroded Share this post Link to post Share on other sites
Geno 1,930 #5 Posted September 22, 2014 edit- I forgot to mention that, when I disengaged the deck after mowing, the tractor abruptly died. That led to all of this happening. Since that- replace fuse, hit the key, pop. rinse and repeat I would start by looking to see if the PTO linkage somewhere hit a wire and pushed it into something that could short it out. 1 Share this post Link to post Share on other sites
GrumpyOldBastige 1 #6 Posted September 22, 2014 (edited) Some more things that popped into mind: 1- previous to this mowing job, I noticed that I could raise the deck, but not lock it into the raised position. 2- I got the switch explanation backwards. I hear both switches when engaging, only one when disengaging. This was when the motor abruptly shut off. 3- I'm betting that's my problem. *ignition switch is two months old. All wiring intact and in good shape. *thinking ground, or the problem is the PTO more looking and exploring to do; I'll report back. Edited September 22, 2014 by GrumpyOldBastige Share this post Link to post Share on other sites
