redsquarebob
wheel horse rear hitch stuck
redsquarebob
how would you get the pin out of the transmission where your hitch is its all set up any ideas how to get it out? i was gunna heat it but i dont think that would be good for the transmission.
Trouty56
This guy is working on the same thing...maybe you should follow his thread.....
woodchuckfarmer
Ive used a ball joint press , works real well
ri702bill
Bob:
I had a similar problem with a 702. I am not a fan of drilling the 1/8" oil holes in the halves near the split - that is just another place for water to collect.
I did sacrafice the original pin by cutting it in 2 places between the slot hitch & the transmission - this allowed removal of the hitch. I then drilled a 9/16" hole almost thru what was stuck in the tramsmission. I then used an air chisel with a round tip & it came right out - same for the hitch pieces.
I then made up a new hitch pin out of 3/4" cold rolled steel in the lathe, a little shorter than the original. I then added short undercuts the outside diameter by .010 inch in 3 places - the center and the 2 spots where the hitch rides. Then both ends were drilled deep & tapped 1/4-28 for grease fittings. The last step was to add 1/8" holes in the middle of the undercuts to intersect the grease holes. No problems after 2 years of use.
Bill
Ron A.
Spud bar, 2 cans of PB Blaster, 1/2 can WD-40, Naval Jelly and 3 grown men taking turns.  Took 3 weeks of soaking.
  • Similar Content
    • tractorboy79
      By tractorboy79
      Hello, I have a gt14 and a old brinly cultivator but I need the correct hitch to put on my tractor (clevis hitch) would clevis hitch fit on the back of a gt14 the same way as a another tractor or will I need to make adjustments? Anything helps? thanks!
    • bob54
      By bob54
      How do I get this pin out,  I've tried heat, rust penetrate, and an air hammer, and just rust penetrate and the air hammer.    I can't get it to move, no matter what I do,,and yes I removed the clips from both ends.  I knew you were thinking about that
    • rwilson
      By rwilson
      This might be a dumb question but i'm sure some of you have dealt with this. How do you get the pin out of the rear when it is rusted in there? I just bought a clevis hitch today but i cant get the pin out to put it on.
