zieg72 209 #1 Posted September 18, 2014 Has anyone taken and fabricated a Wheel Horse snow plow blade to a rear category 0 3 point hitch mount? If so I would like to see pictures. Thanks in advance Share this post Link to post Share on other sites
Austin860 82 #2 Posted September 19, 2014 The blade in the rear doesn't work as we'll as the front blade because if your in a substantial amount of snow it's hard to keep enough tractor to plow. As to where a front plow your driving behind the plowed path, also the snow would pile up against the transmission, not that that would be a big deal. Just my 2 cents Think it would be cool to have one for front and back ! Share this post Link to post Share on other sites
zieg72 209 #3 Posted September 19, 2014 (edited) I appreciate your response, thank you. As Paul Harvey says, now for the rest of the story... This is for my Kubota. Pictured is the frame I have on the rear of it and I have a WheelHorse plow blade that I would like to utilize. Just looking for ideas. The Kubota has a FEL on front. $1900 will buy a Hydraulic 60" plow that fits my tractor or a TSC rear plow for a factory made one, haven't priced it yet. My last idea is to somehow modify the rear axle plow bracket and frame mount it underneath the Kubota and figure out how to lift it with the deck lift mechanism and use the Wheel Horse plow frame. I am in the thinking stages as I still will use my 414-8 to move snow but the thought of 4 wheel drive and the smell of diesel just gets me wanting to go that way. Edited September 19, 2014 by zieg72 1 Share this post Link to post Share on other sites
bubbacola 8 #4 Posted September 19, 2014 Years ago my dad had a kubota with a rear three point grader blade which he could turn around and use backwards as a snow plow.. it worked good.. only thing was you had to turn half way around in the seat to see were you was going.. it got old real fast.. sore neck and back after about 15 minutes of plowing Share this post Link to post Share on other sites
zieg72 209 #5 Posted September 19, 2014 Years ago my dad had a kubota with a rear three point grader blade which he could turn around and use backwards as a snow plow.. it worked good.. only thing was you had to turn half way around in the seat to see were you was going.. it got old real fast.. sore neck and back after about 15 minutes of plowing Yep I hear you. Just seeing what others have done. Share this post Link to post Share on other sites
bitten 134 #6 Posted September 19, 2014 I made a grader box for the rear of my D200 for working on the drive way. In the winter time I use it in places that I cant push the snow and will pull it out and get to it with the front plow. It also gives me more weight. I have a International 656 with a blade on the back that I will use if the snow amount get ahead of me. Like stated it is a pain to use. Share this post Link to post Share on other sites
zieg72 209 #7 Posted September 20, 2014 Thanks for the input guys. I will keep plowing with the wheel horse until I get the change for the Kubota attachment. Share this post Link to post Share on other sites
