papa 0 #1 Posted October 9, 2008 Title pretty much says it all. Does anyone know the Kohler PN for the main jet needle for the K91T carburetor (1960 400 )? (Carter N?) This carb has the adjustabe main needle on top of the carb body. It is NOT a Walbro carb. OR.. if you have a spare needle I could sure use it? Thanks Share this post Link to post Share on other sites
CasualObserver 3,416 #2 Posted October 9, 2008 http://www.crcushman.com/catalog/ill/cartercb.html Share this post Link to post Share on other sites
papa 0 #3 Posted October 9, 2008 Much appreciated jschahl. Thank you. Odd? The carb image you linked has the fuel inlet on the left (mine is on the oppsite side), and the throttle shaft is horizontal where mine is vertical. Also, the image shows the idle mixture screw is on the top (parallel with the main needle), while mine is on the side. However, I would assume that the jets, needles, brass hardware and seals are the same because they are both are Carter N series - hopefully. Share this post Link to post Share on other sites
