vinnyfish1 9 #1 Posted September 10, 2014 I just bought a 1984 c145 automatic from the original owner with a 48 inch cut ... anyway, I got blinded by her good looks and now it's going to cost me some money ...the middle spindle is bad and has a little lateral movement so the center blade is starting to contact the deck ( deck # 0548ms03) I am not really finding any info on replacement and I you guys can help ..... Share this post Link to post Share on other sites
can whlvr 994 #2 Posted September 11, 2014 try one of our used parts guys in the vendors area,ive used a few guys here for parts and have been treated well every time Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #3 Posted September 11, 2014 Will bearings fix you up? Here is a parts list Bearings should be 6203-2RS with a 3/4" ID. 2RS is 2 seals. One bearing likely requires 1 seal and none in the other. Most often a 2RS is cheaper. Just remove the seals you don't need. Garry Share this post Link to post Share on other sites
vinnyfish1 9 #4 Posted September 11, 2014 Thanks guys going to go with gwest's idea since all looks good but the top bearing ...two new ones already on the way Thanks again Share this post Link to post Share on other sites
