SPIKE66 0 #1 Posted September 10, 2014 HI GUYS, IM NEW TO THE WHEEL HORSE TRACTORS AND NEED A LITTLE HELP. I JUST PURCHASED TWO D2OO TRACTORS, ONE HAS THE 20hp KOHLER AND I THINK THE OTHER HAS THE 18hp KOHLER. THE ENGINE TAG IS MISSING ON THE ONE THAT I THINK IS THE 18hp. BOTH ENGINES LOOK THE SAME EXCEPT FOR THE EXHAUST MANIFOLDS AND CARB MANIFOLDS. THE ONE WITH THE MISSING TAG HAS TWO CAST IRON EXHAUSTMANIFOLDS WITH THREADS. THE 20hp HAS METAL EXHAUST TUBES THAT BOLT TO THE ENGINE AND ARE BENT TO THE MUFFLERS. WOULD YOU GUYS KNOW IF THE ENGINE WITHOUT THE TAG IS 18hp? OR DID ALL THE D200'S HAVE 20hp ENGINES? THE ENGINE THAT I THINK IS 18hp KOHLER ALSO HAS BAD PISTON, BAD ROD AND BAD CRANK. THE OTHER PISTON IS OK BECAUSE THE ENGINE WILL RUN ON THE ONE GOOD CYLINDER. NEED TO KNOW IF THE CRANK, PISTON ROD IS THE SAME FOR BOTH 18hp & 20hp? IM GUESSIING THE PISTONS ARE NOT THE SAME. THANKS FOR ANY HELP. Share this post Link to post Share on other sites
"D"- Man 827 #2 Posted September 10, 2014 If I am not mistaken the Kohler K482 = 18 Hp, the Kohler K532 = 20 Hp and the Kohler K582 = 23 Hp. The crankshafts were all the same stroke, the bores were successively larger {although the blocks were all the same otherwise.} It may be possible for one to have a sort of round tubular style intake manifold, while the other has a "squared" style cast aluminum intake manifold. I am certain all D-200's came equipped with the 20 Hp Kohler twins. I cannot answer the question about the differences in the exhaust mountings as I have only seen the kind that bolt on with the two bolts. I know that Wheel Horse also produced a model D-160 with a twin cylinder, however; it was an Onan, which would not interchange parts with the Kohler twins. Here are a couple of pics of the square style Kohler intake manifold, and the two bolt exhaust port area, Mark. Share this post Link to post Share on other sites
SPIKE66 0 #3 Posted September 10, 2014 THANKS MARK. ONE DOES HAVE THE CAST MANIFOLD AND THE OTHER WITH THE TUBE MANIFOLD. BOTH MY D200'S HAVE THE REAR 3 POINT HITCH AND REAR PTO. ONE ALSO HAS THE REAR DUAL BRAKES. MY GUESS IS THEY BOTH HAVE THE KOHLER 20hp ENGINES. Share this post Link to post Share on other sites
SPIKE66 0 #4 Posted September 10, 2014 IF ANYONE HAS D200 KOHLER 20hp PARTS FOR SALE, I NEED CRANKSHAFT, PISTON AND PISTON ROD. THANKS. Share this post Link to post Share on other sites
1maidenfan 202 #5 Posted September 10, 2014 The kohler 20 hp has a spin on oil filter, the 18 hp do not. Have any pix to share with us WELCOME TO REDSQUARE Share this post Link to post Share on other sites
SPIKE66 0 #6 Posted September 10, 2014 THANKS FOR THE INFO. BOTH TRACTORS HAVE SPIN ON FILTERS SO MUST BE 20hp FOR BOTH. WORKING ON BOTH OF THEM AND WILL GET PICS WHEN RUNNING. JUST NEED TO FIND THE ENGINE PARTS TO FIX ONE OF THE ENGINES. THANKS AGAIN FOR THE INFO. Share this post Link to post Share on other sites
SPIKE66 0 #7 Posted September 11, 2014 WILL ANY KOHLER K532 CRANKSHAFT WORK IN ANY K532 ENGINE? OR DO I NEED TO FIND ONE FROM A K532 THAT WAS USED INA WHEEL HORSE D200? THANKS. Share this post Link to post Share on other sites
SPIKE66 0 #8 Posted September 11, 2014 I ALSO SEE GUYS SELLING 20HP ONAN PARTS FOR THE KOHLER K532. WILL THE 20HP ONAN PARTS WORK IN A K532? THANKS AGAIN. Share this post Link to post Share on other sites
km3h 543 #9 Posted September 11, 2014 I ALSO SEE GUYS SELLING 20HP ONAN PARTS FOR THE KOHLER K532. WILL THE 20HP ONAN PARTS WORK IN A K532? THANKS AGAIN. No way will parts from a Kohler work in an Onan. Share this post Link to post Share on other sites
SPIKE66 0 #10 Posted September 11, 2014 OK THANKS. KINDA FIGURED THAT BUT SAW GUYS SELLING THE ONAN PARTS TO FIT BOTH MOTORS. I WILL STICK WITH KOHLER PARTS. Share this post Link to post Share on other sites
pfrederi 19,765 #11 Posted September 11, 2014 WILL ANY KOHLER K532 CRANKSHAFT WORK IN ANY K532 ENGINE? OR DO I NEED TO FIND ONE FROM A K532 THAT WAS USED INA WHEEL HORSE D200? THANKS. Everything, (and more) that you ever need to know about Kohler Cranks (see 3.18) crankshaft-reference.pdf Share this post Link to post Share on other sites
