Austin860 82 #1 Posted September 8, 2014 Hi will a 07-36TL01 tiller fit my electro 12? Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,013 #2 Posted September 8, 2014 Here is the manual to the tiller sold back in the day for the Electro 12 These tillers replaced the 7-1211 This is taken from the Attachment Interchange Current Model Available: 07-36TL05/79370 (Requires Service Assembly 105105 & 85211 Speed Hitch) Here are the manuals for the 1992 model 07-36TL05 Here are the manuals for the 1980-82 model 07-36TL01 you are looking at. The 1978 and later models are much the same because the fuel tank was under the seat which is the biggest difference from your tractor. The hardware to lift the tiller changed. If you get around that it should work. Make sure you get the idler pulleys for the drive belt. Service assembly 105105 8-5211 speed hitch - You may have this if you are using a newer mower deck Garry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,013 #3 Posted September 8, 2014 Should have given this one also Garry Share this post Link to post Share on other sites
Austin860 82 #4 Posted September 8, 2014 Ok. Thanks so I don't think it would work. Shame Share this post Link to post Share on other sites
